Dfu baudrate 28800
Listening mode baudrate 14400
Is there a baud rate i can set to put photon in safe mode?
Dfu baudrate 28800
You can’t do it with just a baud rate, but you can do it by first putting the photon in listening mode with 28800, sending L over serial and then sending x over serial.
(L will put the photon in safe listening mode, and x will reboot the device into normal safe mode if I recall.)
Here’s the thread where I originally found this solution:
This newer thread also provides an option:
You can also use USB Control Requests (e.g. via particle usb safe-mode) to make the device other things than just enter DFU or Listening Mode.
>particle usb --help
Control USB devices
Usage: particle usb <command>
Help: particle help usb <command>
Commands:
list List the devices connected to the host computer
start-listening Put a device into the listening mode
stop-listening Make a device exit the listening mode
safe-mode Put a device into the safe mode
dfu Put a device into the DFU mode
reset Reset a device
configure Update the system USB configuration
