I managed to connect my photon to the local cloud using this tutorial. The server displays this on the console when started
Your server IP address is: 10.0.0.10
server started { host: 'localhost', port: 5683 }
Connection from: 10.0.0.9, connId: 1
on ready { coreID: 'xxxxxxxxxxxxxxxxxxxxxx',
ip: '10.0.0.9',
product_id: 6,
firmware_version: 65535,
cache_key: '_0' }
Core online!
But when I try to access the API like this (Using POSTMAN )
GET http://10.0.0.10:8080/v1/devices
It returns a status 400, like this
"code": 400,
"error": "invalid_request",
"error_description": "The access token was not found"
How do I get the access token, to be used with the local cloud? I tried using the token present in .json files inside .particle folder, but it says invalid token. I could really use some help with this.
@ScruffR Thank you so much for the response. I tried generating an access token, using the link that you mentioned, but I couldn’t figure out much about how to get the user. Should I create a local user in my local server(How do I create a local user?) or is it ok to use the particle account for that? I also tried the Brewskey/spark-server, but the local cloud didn’t identify the device, I got the handshake error I think, and also when running the server for the first time, It didn’t create the folders where the keys were supposed to be stored, as mentioned in the readme page.
EDIT: Managed to get the Brewskey/spark-server running, after a thorough re-do, following all the instructions!!
