How can I turn on LED on wake from sleep()?
I’ve got a dead simple toy I’ve built with my Electron. Literally it’s a button press that sends an email. I’m doing everything I can to save battery consumption so I’m putting my Electron to sleep with the following:
System.sleep(WKP,RISING);
I’ve got a perma proto all soldered up and installed in custom chassis I’ve printed. It’s working wonderfully. Flawlessly, even. :grinning:
My build is missing a feature though - a light to let the user know their input has been received. The chassis its in is solid black, so the on-board LED is not visible. And since (as far as I know) the Electron has to run through the wake-up process and get itself all comfortable before it executes any code, there’s like a 15-second delay between the button press and the activation of an LED. Which is basically the same as having no LED at all.
So how can I:
  • Maintain battery conservation
  • Turn on an LED during boot, OR
  • output the on-board LED’s activity to an external LED wired to the board?
Any ideas? I’ve put this in the “firmware” category in case somebody can think of something I can do in the firmware to turn an LED on. If it’s miscategorized, apologies in advance.
Have a look at system modes and/or system threads. There should also be a ‘startup’ function, though I’m not quite sure on that one. I believe the docs also have an example on how to copy the onboard LED to an external one, if you want the ‘full’ status.
Beauty, thanks for taking the time. I’ll have a look for that example code for sure, that’d work perfectly for me.
Cheers!
