Wake up from sleep with switch - Electron
I need some help from the experts. I use the following command to go into sleep mode for more or less
three days.
System.sleep(SLEEP_MODE_SOFTPOWEROFF, SLEEP_MODE_SOFTPOWEROFF_SECONDS);
Sometimes the user must wake up the unit with a reset switch. I have a Normally open switch I would like to use to wake up the Electron. What would the best route to explore ?
Tx
James
SLEEP_MODE_SOFTPOWEROFF is a special kind of deep sleep where the device can be woken by a rising edge on the WKP pin.
https://docs.particle.io/reference/firmware/electron/#sleep-sleep-
