Historical Location Tracking Route with Tracker SOM
Hello all,
@rickkas7
@gusgonnet
I would like to Know if there is a way to track the Device Location in Particle Cloud,
i know about the Tracker Edge Firmware which publishes the location data and it will be available in the particle map widget.
But i want to have the map along with its travel route as visualization
is it possible in the particle cloud location of devices widget??
Thanks in Advance
There is no facility to generate a map automatically from your own website.
The recommended method is to use the historical location API and use your own mapping service.
