Busy day already:
Not getting good results for the Argon with a wifi and mesh activated antenna, but everything else today was good.
At Home Argon using wifi and Antenna for wifi only:
- Xenon with Antenna activated but not attached 10 m
- Xenon default. no Antenna and not activated 40 m
- Xenon with Antenna attached and activated 80 m (also re-connects well)
No advantage if the Argon is using Particle Featherwing or activating the mesh Antenna (I think it was worse with Mesh Antenna activated)
At School (Heavy concrete lots of metal, busy wifi, new Ethernet setup. Could get more details if anyone is interested.)
See image. Used the normal Argon setup, but had a Xenon with Antenna activated near the window, Argon in the middle of the classroom.
Basically had good stable connection at about 150 m, did not try any farther.
A very good day with the Mesh devices.
