So today I tried the same diagram at school but using Xenons with Antenna (even though with the Photon I was ripping the Antenna connector off the board. I used to just pull the connector straight of with a slight bend, do others use pliers, bend, pull straight off???)
Note: I have now managed to take an Antenna off a Xenon without ripping the connector of the board, Not sure why I was having troubles with the Photons.
It seemed like things were about 10 meters better but with repeat attempts they were not stable. So it looked like the Antenna has no improvement to the Xenons. On digging deeper it looks like the Antenna is not yet activated for the Xenons but only helps the Argon with Wifi.
By @rickkas7
I’m pretty sure the function to select the external mesh antenna is not yet implemented (as of 0.8.0-rc.25).
Everything I have just said in this entire blog is now out of date! Looks like version 26 is out including the Android App
