High Data Usage - Boron
I have several devices at different locations within the US running the same code. The code doesn’t really do much it will only respond when a PIN is open/closed One of the device has used significantly more data (30 MB) compared to the rest of the devices (0.5 MB). This one device’s signal strength fluctuates between 7% to 25%. Is this normal for a device to use so much more data when signal strength is subpar. The next device with the second to worst signal strength has on average 35% signal strength but only uses (0.7 MB) during the same period and has similar number of IO calls
Low signal devices can chew through data while connecting. Can you DM me the DeviceID so that I can pull the logs?
