Hi, I have a TOF sensor I am using to at the top of a roll up door. I am wanting to add a line to the loop sketch that will only run D7 if the sensor is picking up 140mm and its like this for 10 minutes.
thanks in advancel
unsigned char ok_flag;
unsigned char fail_flag;
unsigned short lenth_val = 0;
unsigned char i2c_rx_buf[16];
unsigned char dirsend_flag=0;
int LID = D7;
Wire.begin();
pinMode(LID, OUTPUT);
int x=ReadDistance();
Serial.print(x);
Serial.println(" mm");
if (lenth_val < 140) { /* looking to add a timer here before tripping the relays, <140mm for 10 minutes then digitalwrite High..../*
digitalWrite(LID, HIGH);
delay(1000);
digitalWrite(LID, LOW);
int serial_putc( char c, struct __file * )
Serial.write( c );
return c;}
void SensorRead(unsigned char addr,unsigned char* datbuf,unsigned char cnt)
unsigned short result=0;
// step 1: instruct sensor to read echoes
Wire.beginTransmission(82); // transmit to device #82 (0x52)
// the address specified in the datasheet is 164 (0xa4)
// but i2c adressing uses the high 7 bits so it's 82
Wire.write(byte(addr)); // sets distance data address (addr)
Wire.endTransmission(); // stop transmitting
// step 2: wait for readings to happen
delay(1); // datasheet suggests at least 30uS
// step 3: request reading from sensor
Wire.requestFrom(82, cnt); // request cnt bytes from slave device #82 (0x52)
// step 5: receive reading from sensor
if (cnt <= Wire.available()) { // if two bytes were received
*datbuf++ = Wire.read(); // receive high byte (overwrites previous reading)
*datbuf++ = Wire.read(); // receive low byte as lower 8 bits
int ReadDistance(){
SensorRead(0x00,i2c_rx_buf,2);
lenth_val=i2c_rx_buf[0];
lenth_val=lenth_val<<8;
lenth_val|=i2c_rx_buf[1];
delay(300);
return lenth_val;
