I am quite new with some of the syntax I am seeing from third parties, such as E-ink libraries from Waveshare - which I would like to integrate with my Electron. I will also say that my knowledge of C++ is still quite limited too - so please excuse my ignorance.
For example; if I create a project and add in the code provided by Waveshare, such as this:
https://github.com/waveshare/e-Paper/tree/master/Arduino/epd1in54_V2
I run into all sorts of issues attempting to compile code in the particle wed IDE. After adding in the *.h and *.cpp files - the first issue to note, its referring to “arduino” includes - which I’ve commented out to try to progress things.
The first error scenario which I don’t know how to solve seems to be related to some of the “baked in” functions of the particle OS.
Within the epdif.cpp file, it complains “‘digitalWrite’ was not declared in this scope”.
The Waveshare example code seems to be attempting to wrap-up low level functions into a method in the EpdIf class. The code I am referring to is as follows:
void EpdIf::DigitalWrite(int pin, int value){
digitalWrite(pin, value);
I don’t see from the documentation how to add includes to allow the “digitalWrite” function to be recognised (i.e. you don’t need to use any includes etc if you were to use the digitalRead/digitalWrite functions in a new project - you can call it directly in the “main” loop of the code, as is the basis of many LED blinking starter code).
When creating additional .cpp/.h files in the wed IDE - is there something that needs to be done to make those files “aware” of (what I understand to be) baked-in OS functions in particle world? Programming microcontrollers in the past (many years ago, and just in C) - this was always a case of ensuring the appropriate include libraries were defined.
Am I missing something here?
Any advice would be greatly appreciated.
