'particle' not declared in this scope
Hi I don’t understand what wrong in my code:
This is the partial code
float PressV;
Time.zone(+1);
Particle.variable(“PressV”,PressV);
and this is the error message
stazmeteovisala.cpp: In function ‘void setup()’:
stazmeteovisala.cpp:42:1: error: ‘Particle’ was not declared in this scope
Thanks Valentino
Could you share the link of your project from the Web IDE? That way we can have a look at the exact project without having to make guesses.
When trying to edit the title of you post, Discourse told me I couldn't because there was already a topic with the exact error description as yours. Had you tried looking for that already?
Thanks for your answer, before to write I check but I was unablebthe find. Now I see the probabilty answer In your answer(Firmware version)c tomorrow I check.
Hi Moors7 thanks a lot I just change the firmware version and now everything is ok.
:blush::+1:
