Help for send local URL
Hello,
I want to send this URL from my Photon, via my local network (http://hd1.freebox.fr/pub/remote_control?code=12345678&key=power) or “power” represents a keyword.
If I send this URL through my web browser, it controls my TV box.
I installed the library HttpClient.h, I looked at the example but I do not see how to indicate my URL. Hostname, port, patch …?!?
Thanks for help
This sample shows how
For your case
    request.hostname = "hd1.freebox.fr";
    request.port = 80;
    request.path = "/pub/remote_control";
Or what else are you missing?
Since this is a GET request, you can add the parameters right on the URL like this:
request.path = "/pub/remote_control?code=12345678&key=power";
Thanks but i’m already try this…
#include <HttpClient.h>
* Declaring the variables.
unsigned int nextTime = 0;    // Next time to contact the server
HttpClient http;
http_header_t headers[] = {
    //  { "Content-Type", "application/json" },
    //  { "Accept" , "application/json" },
    { "Accept" , "*/*"},
http_request_t request;
http_response_t response;
    if (nextTime > millis()) {
        return;
    Serial.println();
    Serial.println("Application>\tStart of Loop.");
    // Request path and body can be set at runtime or at setup.
    request.hostname = "http://hd1.freebox.fr";
    request.port = 80;
    request.path = "/pub/remote_control?code=86700567&key=power";
    // The library also supports sending a body with your request:
    //request.body = "{\"key\":\"value\"}";
    // Get request
    http.get(request, response, headers);
    Serial.print("Application>\tResponse status: ");
    Serial.println(response.status);
    Serial.print("Application>\tHTTP Response Body: ");
    Serial.println(response.body);
    nextTime = millis() + 10000;
I use the Particle Web IDE, is this a problem ?
Does it work?
Does it not work?
If not, then what does it do?
What’s the serial output?
Have a close look what the difference is between your hostname and mine (or the one in the sample you copied the code from) :wink:
It does not work and do nothing !
I’m working with the Web IDE so, don’t have a serial monitor
How can I see the result of sending the request?
I just understood how to have the monitor serie;)
it says 1 time “: ok”
I found … you should not put “http: //” in the host
So, I found another library, simpler.
#include "rest_client.h"
RestClient client = RestClient("hd1.freebox.fr");
  Serial.println("starting...");
String response;
  response = "";
  int statusCode = client.get("/pub/remote_control?code=86700567&key=power", &response);
  Serial.print("Status code from server: ");
  Serial.println(statusCode);
  Serial.print("Response body from server: ");
  Serial.println(response);
  delay(5000);
I am proud of myself :wink:
Exactly that :+1:
