Hardware problem with Photon? Touching top of module crashes it
One of my photons seems to have a hardware problem : the connection of the module to the board seems flakey…
If it gets touched, even a little, it immediately crashes and restarts. Sometimes it restarts just fine, sometimes not so much and it takes a few resets and re-connect of the wifi via the app to get it back…
Does this sound familar to anyone? Should I try for a return?
thanks
Brian
same problem here
@brianwyld, this is a know issue. Look here:
I can confirm this issue with at least one photon I have.
Even a slight amount of pressure on the top of the P0 shield causes a short and resets the photon.
Maybe it’s a feature ? Extra reset button?
The metal case of the module on the Photon is not as stiff as the metal housing on the Core. Pressing down on the housing can cause a short on the photon. This doubles as a sort of “reset-button” since the photon will cut power / reset to protect itself during the short, although I would guess that’s probably not encouraged. :slight_smile:
David
