Hi, I’m developing a project using particle photon where there are three different interrupts on DAC, D6 and D7. Each has their separate ISR. However, when I triggered them at the same time using a single signal, only one of them got registered. Any ideas on how I can get all of them handled in such a case?
What device OS are you running on your device?
I cannot confirm what you are seeing.
This is my test code
SYSTEM_THREAD(ENABLED)
volatile int a6;
volatile int d6;
volatile int d7;
pinMode(A6, INPUT_PULLUP);
pinMode(D6, INPUT_PULLUP);
pinMode(D7, INPUT_PULLUP);
attachInterrupt(A6, ISRa6, FALLING);
attachInterrupt(D6, ISRd6, FALLING);
attachInterrupt(D7, ISRd7, FALLING);
Serial.printlnf("%d,%d,%d", a6, d6, d7);
delay(1000);
void ISRa6() {
static uint32_t ms = 0;
if (millis() - ms < 50) return;
ms = millis();
a6++;
void ISRd6() {
ms = millis();
d6++;
void ISRd7() {
ms = millis();
d7++;
I briged all three pins to the same trigger source to cause absolutely synchronous triggers and they all also fire.
Would you be able to explain line by line what the ISR functions are doing - is this a debounce?
Yup, the first three lines are exactly that, the only "working" line is the increment of each respectrive data variable.
Without the debounce I got dozends to even hundreds of triggers with one touch of the jumper wire to GND.
