Hello,
I have a particle photon and i have the GT511C3 fingerprint scanner connected as shown :
I am trying to use the sample code on this Github: https://github.com/pkourany/FPS_GT511C3_Library , and flashing it to my photon on Particle build but I’m a little confused as this is my first time using the photon.
Any help would be greatly appreciated!
Thank you!
@ethanmcm13, can you please describe your wiring. The picture makes no sense to me. What are the resistors for?
@peekay123, I’m using the a JST cable, so black is connected to VIN pin. 2nd cable is connected to RX pin, 3rd cable is connected to ground using the 2 resistors and 4th connected to the TX pin. I was trying to follow the setup of this video: https://www.youtube.com/watch?v=3tI2IyBXDKI
@ethanmcm13, The pinout is as follows:
The resistors make no sense to me. You should connect as follows based on the picture’s pin numbering:
Photon Module
RX 1 (TX)
TX 2 (RX)
GND 3 (GND)
Vin 4 (Vin)
