Green LED never stops blinking after antenna was reconnected to Electron
Dear all
After reconnecting antenna to Electron it never stops blinking green. I have not found any tips for this case. My OS 0.8.0-rc.14. Before reconnecting antenna it used to work fine. No reflashing has been done yet. regards
Dmitry
Did you, by any chance, remove/reattach the antenna while the device was running?
First, just to bring everything to a clean slate, can you run
particle update
and
particle flash --usb tinker
in CLI, with the device in DFU Mode and connected via USB?
From there, would you mind downloading and installing Electron Cloud Debug (link) on the device? Upon doing so, please send me about ~10 minutes or so of logs produced by the device while it’s having trouble connecting with the Cloud. It’s worth blocking out the Device ID and ICCID of this device as reported in Cloud Debug (but please PM me those details).
The best way to produce these logs is with particle serial monitor --follow in CLI.
Please note both installation and de-installation instructions contained within the above Cloud Debug link!
Detaching/reattaching antenna is harmful?
Actually I used to do it with my test to simulate a no-signal case (for example in the Underground)
Hi and thanks for the tips. Done as suggested (see below). I will send you my Device ID and ICCID via PM now. Looking forward to your suggestings how to fix it
Below is a long log produced when
C:\Users\bss816\Downloads>particle serial monitor --follow
Polling for available serial device...
Opening serial monitor for com port: "COM10"
Serial monitor opened successfully:
   264.090 AT send      10 "AT+CREG?\r\n"
   264.397 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   264.399 AT read OK    6 "\r\nOK\r\n"
   264.399 AT send      11 "AT+CGREG?\r\n"
   264.431 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   264.439 AT read OK    6 "\r\nOK\r\n"
   279.443 AT send      10 "AT+CREG?\r\n"
   279.474 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   279.481 AT read OK    6 "\r\nOK\r\n"
   279.481 AT send      11 "AT+CGREG?\r\n"
   279.513 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   279.514 AT read OK    6 "\r\nOK\r\n"
   294.518 AT send      10 "AT+CREG?\r\n"
   294.549 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   294.556 AT read OK    6 "\r\nOK\r\n"
   294.556 AT send      11 "AT+CGREG?\r\n"
   294.588 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   294.590 AT read OK    6 "\r\nOK\r\n"
   309.594 AT send      10 "AT+CREG?\r\n"
   310.062 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   310.069 AT read OK    6 "\r\nOK\r\n"
   310.069 AT send      11 "AT+CGREG?\r\n"
   310.101 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   310.102 AT read OK    6 "\r\nOK\r\n"
   325.106 AT send      10 "AT+CREG?\r\n"
   325.137 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   325.144 AT read OK    6 "\r\nOK\r\n"
   325.144 AT send      11 "AT+CGREG?\r\n"
   325.176 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   325.177 AT read OK    6 "\r\nOK\r\n"
CSD Registration Denied
PSD Registration Denied
0000325178 [system] WARN: Resetting WLAN due to WLAN_WD_TO()
[ Modem::powerOff ] = = = = = = = = = = = = = =
   325.178 AT send       4 "AT\r\n"
   325.207 AT read OK    6 "\r\nOK\r\n"
   325.207 AT send      12 "AT+CPWROFF\r\n"
   325.341 AT read OK    6 "\r\nOK\r\n"
[ ElectronSerialPipe::end ] pipeTx=0 pipeRx=0
[ ElectronSerialPipe::begin ] pipeTx=0 pipeRx=0
[ Modem::powerOn ] = = = = = = = = = = = = = =
   326.651 AT send       4 "AT\r\n"
   326.793 AT read UNK   3 "AT\r"
   326.794 AT read OK    6 "\r\nOK\r\n"
   326.794 AT send       9 "AT+CGMM\r\n"
   326.826 AT read UNK   8 "AT+CGMM\r"
   326.827 AT read UNK  13 "\r\nSARA-G350\r\n"
   326.828 AT read OK    6 "\r\nOK\r\n"
   327.029 AT send       6 "ATE0\r\n"
   327.060 AT read UNK   5 "A\xd4E0\r"
   327.061 AT read OK    6 "\r\nOK\r\n"
   327.061 AT send      11 "AT+CMEE=2\r\n"
   327.093 AT read OK    6 "\r\nOK\r\n"
   327.093 AT send      19 "AT+CMER=1,0,0,2,1\r\n"
   327.126 AT read OK    6 "\r\nOK\r\n"
   327.126 AT send      15 "AT+IPR=115200\r\n"
   327.157 AT read OK    6 "\r\nOK\r\n"
   327.257 AT send      10 "AT+CPIN?\r\n"
   327.292 AT read ERR  37 "\r\n+CME ERROR: operation not allowed\r\n"
   327.854 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   328.294 AT send      10 "AT+CPIN?\r\n"
   328.326 AT read  +   16 "\r\n+CPIN: READY\r\n"
   328.328 AT read OK    6 "\r\nOK\r\n"
[ Modem::init ] = = = = = = = = = = = = = = =
   328.328 AT send       9 "AT+CGSN\r\n"
   328.362 AT read UNK  19 "\r\n359315075381268\r\n"
   328.374 AT read OK    6 "\r\nOK\r\n"
   328.374 AT send       9 "AT+CGMI\r\n"
   328.407 AT read UNK  10 "\r\nu-blox\r\n"
   328.408 AT read OK    6 "\r\nOK\r\n"
   328.408 AT send       9 "AT+CGMR\r\n"
   328.440 AT read UNK   9 "\r\n08.70\r\n"
   328.442 AT read OK    6 "\r\nOK\r\n"
   328.442 AT send       6 "ATI9\r\n"
   328.476 AT read UNK  16 "\r\n08.70,A00.02\r\n"
   328.478 AT read OK    6 "\r\nOK\r\n"
   328.478 AT send       9 "AT+CCID\r\n"
   328.511 AT read  +   30 "\r\n+CCID: MY ICCID\r\n"
   328.513 AT read OK    6 "\r\nOK\r\n"
   328.513 AT send      11 "AT+CMGF=1\r\n"
   328.545 AT read OK    6 "\r\nOK\r\n"
   328.545 AT send      13 "AT+CNMI=2,1\r\n"
   328.578 AT read OK    6 "\r\nOK\r\n"
   328.578 AT send       9 "AT+CIMI\r\n"
   328.611 AT read UNK  19 "\r\n214074303246741\r\n"
   328.623 AT read OK    6 "\r\nOK\r\n"
   328.623 AT send      13 "AT+COPS=3,2\r\n"
   328.656 AT read OK    6 "\r\nOK\r\n"
   328.656 AT send      11 "AT+UPSV=1\r\n"
   328.689 AT read OK    6 "\r\nOK\r\n"
0000328690 [system] INFO: Sim Ready
0000328691 [system] INFO: ARM_WLAN_WD 1
[ Modem::register ] = = = = = = = = = = = = = =
   328.690 AT send      12 "AT+CGREG=2\r\n"
   328.722 AT read OK    6 "\r\nOK\r\n"
   328.722 AT send      11 "AT+CREG=2\r\n"
   328.754 AT read OK    6 "\r\nOK\r\n"
   328.754 AT send      10 "AT+CREG?\r\n"
   328.787 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   328.789 AT read OK    6 "\r\nOK\r\n"
   328.789 AT send      11 "AT+CGREG?\r\n"
   328.821 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   328.823 AT read OK    6 "\r\nOK\r\n"
   328.823 AT send      10 "AT+URAT?\r\n"
   328.857 AT read ERR  23 "\r\n+CME ERROR: unknown\r\n"
   328.857 AT send      10 "AT+CREG?\r\n"
   328.889 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   328.891 AT read OK    6 "\r\nOK\r\n"
   328.891 AT send      11 "AT+CGREG?\r\n"
   328.925 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   328.932 AT read OK    6 "\r\nOK\r\n"
   334.375 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   334.377 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   343.936 AT send      10 "AT+CREG?\r\n"
   343.968 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   343.970 AT read OK    6 "\r\nOK\r\n"
   343.970 AT send      11 "AT+CGREG?\r\n"
   344.002 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   344.011 AT read OK    6 "\r\nOK\r\n"
   344.410 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   358.304 AT read  +   12 "\r\n+CREG: 0\r\n"
   358.308 AT read  +   13 "\r\n+CGREG: 0\r\n"
   358.310 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   358.312 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   358.313 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   359.015 AT send      10 "AT+CREG?\r\n"
   359.249 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   359.257 AT read OK    6 "\r\nOK\r\n"
   359.257 AT send      11 "AT+CGREG?\r\n"
   359.289 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   359.290 AT read OK    6 "\r\nOK\r\n"
   364.880 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   370.687 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   374.294 AT send      10 "AT+CREG?\r\n"
   374.325 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   374.327 AT read OK    6 "\r\nOK\r\n"
   374.327 AT send      11 "AT+CGREG?\r\n"
   374.359 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   374.360 AT read OK    6 "\r\nOK\r\n"
   389.364 AT send      10 "AT+CREG?\r\n"
   389.616 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   389.623 AT read OK    6 "\r\nOK\r\n"
   389.623 AT send      11 "AT+CGREG?\r\n"
   389.655 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   389.656 AT read OK    6 "\r\nOK\r\n"
   395.962 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   404.660 AT send      10 "AT+CREG?\r\n"
   404.691 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   404.703 AT read OK    6 "\r\nOK\r\n"
   404.703 AT send      11 "AT+CGREG?\r\n"
   404.735 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   404.744 AT read OK    6 "\r\nOK\r\n"
   419.748 AT send      10 "AT+CREG?\r\n"
   419.982 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   419.989 AT read OK    6 "\r\nOK\r\n"
   419.989 AT send      11 "AT+CGREG?\r\n"
   420.021 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   420.022 AT read OK    6 "\r\nOK\r\n"
   432.676 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   435.026 AT send      10 "AT+CREG?\r\n"
   435.058 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   435.066 AT read OK    6 "\r\nOK\r\n"
   435.066 AT send      11 "AT+CGREG?\r\n"
   435.098 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   435.099 AT read OK    6 "\r\nOK\r\n"
   440.428 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   447.135 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   450.103 AT send      10 "AT+CREG?\r\n"
   450.134 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   450.141 AT read OK    6 "\r\nOK\r\n"
   450.141 AT send      11 "AT+CGREG?\r\n"
   450.173 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   450.175 AT read OK    6 "\r\nOK\r\n"
   465.179 AT send      10 "AT+CREG?\r\n"
   465.210 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   465.212 AT read OK    6 "\r\nOK\r\n"
   465.212 AT send      11 "AT+CGREG?\r\n"
   465.244 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   465.245 AT read OK    6 "\r\nOK\r\n"
   469.170 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   479.362 AT read  +   12 "\r\n+CREG: 3\r\n"
   479.365 AT read  +   13 "\r\n+CGREG: 3\r\n"
   479.367 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   479.647 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   480.249 AT send      10 "AT+CREG?\r\n"
   480.280 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   480.282 AT read OK    6 "\r\nOK\r\n"
   480.282 AT send      11 "AT+CGREG?\r\n"
   480.314 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   480.323 AT read OK    6 "\r\nOK\r\n"
   495.327 AT send      10 "AT+CREG?\r\n"
   495.667 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   495.675 AT read OK    6 "\r\nOK\r\n"
   495.675 AT send      11 "AT+CGREG?\r\n"
   495.707 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   495.708 AT read OK    6 "\r\nOK\r\n"
   510.712 AT send      10 "AT+CREG?\r\n"
   510.743 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   510.754 AT read OK    6 "\r\nOK\r\n"
   510.754 AT send      11 "AT+CGREG?\r\n"
   510.786 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   510.787 AT read OK    6 "\r\nOK\r\n"
   525.791 AT send      10 "AT+CREG?\r\n"
   526.269 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   526.276 AT read OK    6 "\r\nOK\r\n"
   526.276 AT send      11 "AT+CGREG?\r\n"
   526.308 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   526.309 AT read OK    6 "\r\nOK\r\n"
   541.313 AT send      10 "AT+CREG?\r\n"
   541.344 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   541.351 AT read OK    6 "\r\nOK\r\n"
   541.351 AT send      11 "AT+CGREG?\r\n"
   541.383 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   541.384 AT read OK    6 "\r\nOK\r\n"
   556.388 AT send      10 "AT+CREG?\r\n"
   556.871 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   556.878 AT read OK    6 "\r\nOK\r\n"
   556.878 AT send      11 "AT+CGREG?\r\n"
   556.910 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   556.911 AT read OK    6 "\r\nOK\r\n"
   571.915 AT send      10 "AT+CREG?\r\n"
   571.946 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   571.953 AT read OK    6 "\r\nOK\r\n"
   571.953 AT send      11 "AT+CGREG?\r\n"
   571.985 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   571.986 AT read OK    6 "\r\nOK\r\n"
   586.990 AT send      10 "AT+CREG?\r\n"
   587.021 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   587.028 AT read OK    6 "\r\nOK\r\n"
   587.028 AT send      11 "AT+CGREG?\r\n"
   587.060 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   587.061 AT read OK    6 "\r\nOK\r\n"
   602.065 AT send      10 "AT+CREG?\r\n"
   602.096 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   602.107 AT read OK    6 "\r\nOK\r\n"
   602.107 AT send      11 "AT+CGREG?\r\n"
   602.139 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   602.140 AT read OK    6 "\r\nOK\r\n"
   617.144 AT send      10 "AT+CREG?\r\n"
   617.604 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   617.611 AT read OK    6 "\r\nOK\r\n"
   617.611 AT send      11 "AT+CGREG?\r\n"
   617.643 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   617.644 AT read OK    6 "\r\nOK\r\n"
   632.648 AT send      10 "AT+CREG?\r\n"
   632.679 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   632.686 AT read OK    6 "\r\nOK\r\n"
   632.686 AT send      11 "AT+CGREG?\r\n"
   632.718 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   632.719 AT read OK    6 "\r\nOK\r\n"
0000632720 [system] WARN: Resetting WLAN due to WLAN_WD_TO()
   632.720 AT send       4 "AT\r\n"
   632.749 AT read OK    6 "\r\nOK\r\n"
   632.749 AT send      12 "AT+CPWROFF\r\n"
   632.883 AT read OK    6 "\r\nOK\r\n"
   634.193 AT send       4 "AT\r\n"
   634.336 AT read UNK   3 "AT\r"
   634.337 AT read OK    6 "\r\nOK\r\n"
   634.337 AT send       9 "AT+CGMM\r\n"
   634.370 AT read UNK   8 "A\\+CGMM\r"
   634.371 AT read UNK  13 "\r\nSARA-G350\r\n"
   634.372 AT read OK    6 "\r\nOK\r\n"
   634.573 AT send       6 "ATE0\r\n"
   634.605 AT read UNK   5 "A\xd4E0\r"
   634.606 AT read OK    6 "\r\nOK\r\n"
   634.606 AT send      11 "AT+CMEE=2\r\n"
   634.638 AT read OK    6 "\r\nOK\r\n"
   634.638 AT send      19 "AT+CMER=1,0,0,2,1\r\n"
   634.671 AT read OK    6 "\r\nOK\r\n"
   634.671 AT send      15 "AT+IPR=115200\r\n"
   634.703 AT read OK    6 "\r\nOK\r\n"
   634.803 AT send      10 "AT+CPIN?\r\n"
   634.837 AT read ERR  37 "\r\n+CME ERROR: operation not allowed\r\n"
   635.392 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   635.838 AT send      10 "AT+CPIN?\r\n"
   635.870 AT read  +   16 "\r\n+CPIN: READY\r\n"
   635.879 AT read OK    6 "\r\nOK\r\n"
   635.879 AT send       9 "AT+CGSN\r\n"
   635.913 AT read UNK  19 "\r\n359315075381268\r\n"
   635.925 AT read OK    6 "\r\nOK\r\n"
   635.925 AT send       9 "AT+CGMI\r\n"
   635.958 AT read UNK  10 "\r\nu-blox\r\n"
   635.959 AT read OK    6 "\r\nOK\r\n"
   635.959 AT send       9 "AT+CGMR\r\n"
   635.992 AT read UNK   9 "\r\n08.70\r\n"
   635.994 AT read OK    6 "\r\nOK\r\n"
   635.994 AT send       6 "ATI9\r\n"
   636.028 AT read UNK  16 "\r\n08.70,A00.02\r\n"
   636.029 AT read OK    6 "\r\nOK\r\n"
   636.029 AT send       9 "AT+CCID\r\n"
   636.063 AT read  +   30 "\r\n+CCID: MY ICCID\r\n"
   636.065 AT read OK    6 "\r\nOK\r\n"
   636.065 AT send      11 "AT+CMGF=1\r\n"
   636.097 AT read OK    6 "\r\nOK\r\n"
   636.097 AT send      13 "AT+CNMI=2,1\r\n"
   636.130 AT read OK    6 "\r\nOK\r\n"
   636.130 AT send       9 "AT+CIMI\r\n"
   636.163 AT read UNK  19 "\r\n214074303246741\r\n"
   636.166 AT read OK    6 "\r\nOK\r\n"
   636.166 AT send      13 "AT+COPS=3,2\r\n"
   636.199 AT read OK    6 "\r\nOK\r\n"
   636.199 AT send      11 "AT+UPSV=1\r\n"
   636.231 AT read OK    6 "\r\nOK\r\n"
0000636232 [system] INFO: Sim Ready
0000636233 [system] INFO: ARM_WLAN_WD 1
   636.232 AT send      12 "AT+CGREG=2\r\n"
   636.266 AT read OK    6 "\r\nOK\r\n"
   636.266 AT send      11 "AT+CREG=2\r\n"
   636.300 AT read OK    6 "\r\nOK\r\n"
   636.300 AT send      10 "AT+CREG?\r\n"
   636.332 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   636.334 AT read OK    6 "\r\nOK\r\n"
   636.334 AT send      11 "AT+CGREG?\r\n"
   636.366 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   636.368 AT read OK    6 "\r\nOK\r\n"
   636.368 AT send      10 "AT+URAT?\r\n"
   636.402 AT read ERR  23 "\r\n+CME ERROR: unknown\r\n"
   636.402 AT send      10 "AT+CREG?\r\n"
   636.435 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   636.437 AT read OK    6 "\r\nOK\r\n"
   636.437 AT send      11 "AT+CGREG?\r\n"
   636.470 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   636.471 AT read OK    6 "\r\nOK\r\n"
   641.228 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   641.231 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   641.952 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   644.126 AT read  +   12 "\r\n+CREG: 3\r\n"
   644.129 AT read  +   13 "\r\n+CGREG: 3\r\n"
   644.131 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   644.133 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   644.136 AT read  +   13 "\r\n+CGREG: 0\r\n"
   644.138 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   651.475 AT send      10 "AT+CREG?\r\n"
   651.507 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   651.514 AT read OK    6 "\r\nOK\r\n"
   651.514 AT send      11 "AT+CGREG?\r\n"
   651.546 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   651.547 AT read OK    6 "\r\nOK\r\n"
   656.284 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   656.286 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   656.288 AT read  +   13 "\r\n+CGREG: 3\r\n"
   656.290 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   666.551 AT send      10 "AT+CREG?\r\n"
   666.582 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   666.584 AT read OK    6 "\r\nOK\r\n"
   666.584 AT send      11 "AT+CGREG?\r\n"
   666.616 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   666.617 AT read OK    6 "\r\nOK\r\n"
   676.894 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   681.621 AT send      10 "AT+CREG?\r\n"
   681.653 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   681.661 AT read OK    6 "\r\nOK\r\n"
   681.661 AT send      11 "AT+CGREG?\r\n"
   681.693 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   681.694 AT read OK    6 "\r\nOK\r\n"
   681.972 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   692.642 AT read  +   12 "\r\n+CREG: 0\r\n"
   692.644 AT read  +   13 "\r\n+CGREG: 0\r\n"
   692.646 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   696.698 AT send      10 "AT+CREG?\r\n"
   696.729 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   696.740 AT read OK    6 "\r\nOK\r\n"
   696.740 AT send      11 "AT+CGREG?\r\n"
   696.772 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   696.773 AT read OK    6 "\r\nOK\r\n"
   701.041 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   711.777 AT send      10 "AT+CREG?\r\n"
   711.808 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   711.815 AT read OK    6 "\r\nOK\r\n"
   711.815 AT send      11 "AT+CGREG?\r\n"
   711.847 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   711.849 AT read OK    6 "\r\nOK\r\n"
   713.751 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   714.448 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   722.931 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   725.050 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   725.756 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   726.462 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   726.853 AT send      10 "AT+CREG?\r\n"
   726.884 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   726.886 AT read OK    6 "\r\nOK\r\n"
   726.886 AT send      11 "AT+CGREG?\r\n"
   726.918 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   726.927 AT read OK    6 "\r\nOK\r\n"
   741.931 AT send      10 "AT+CREG?\r\n"
   741.962 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   741.974 AT read OK    6 "\r\nOK\r\n"
   741.974 AT send      11 "AT+CGREG?\r\n"
   742.006 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   742.007 AT read OK    6 "\r\nOK\r\n"
   757.011 AT send      10 "AT+CREG?\r\n"
   757.042 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   757.053 AT read OK    6 "\r\nOK\r\n"
   757.053 AT send      11 "AT+CGREG?\r\n"
   757.085 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   757.086 AT read OK    6 "\r\nOK\r\n"
   762.479 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   766.716 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   772.090 AT send      10 "AT+CREG?\r\n"
   772.121 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   772.133 AT read OK    6 "\r\nOK\r\n"
   772.133 AT send      11 "AT+CGREG?\r\n"
   772.165 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   772.166 AT read OK    6 "\r\nOK\r\n"
   787.170 AT send      10 "AT+CREG?\r\n"
   787.201 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   787.203 AT read OK    6 "\r\nOK\r\n"
   787.203 AT send      11 "AT+CGREG?\r\n"
   787.235 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   787.236 AT read OK    6 "\r\nOK\r\n"
   802.240 AT send      10 "AT+CREG?\r\n"
   802.348 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   802.356 AT read OK    6 "\r\nOK\r\n"
   802.356 AT send      11 "AT+CGREG?\r\n"
   802.388 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   802.389 AT read OK    6 "\r\nOK\r\n"
   805.887 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   813.534 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   813.536 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   813.538 AT read  +   12 "\r\n+CREG: 3\r\n"
   813.540 AT read  +   13 "\r\n+CGREG: 3\r\n"
   813.542 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   817.393 AT send      10 "AT+CREG?\r\n"
   817.582 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   817.590 AT read OK    6 "\r\nOK\r\n"
   817.590 AT send      11 "AT+CGREG?\r\n"
   817.622 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   817.623 AT read OK    6 "\r\nOK\r\n"
   832.627 AT send      10 "AT+CREG?\r\n"
   832.658 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   832.669 AT read OK    6 "\r\nOK\r\n"
   832.669 AT send      11 "AT+CGREG?\r\n"
   832.701 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   832.702 AT read OK    6 "\r\nOK\r\n"
   847.706 AT send      10 "AT+CREG?\r\n"
   848.184 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   848.191 AT read OK    6 "\r\nOK\r\n"
   848.191 AT send      11 "AT+CGREG?\r\n"
   848.223 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   848.224 AT read OK    6 "\r\nOK\r\n"
   863.228 AT send      10 "AT+CREG?\r\n"
   863.259 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   863.266 AT read OK    6 "\r\nOK\r\n"
   863.266 AT send      11 "AT+CGREG?\r\n"
   863.298 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   863.299 AT read OK    6 "\r\nOK\r\n"
   878.303 AT send      10 "AT+CREG?\r\n"
   878.786 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   878.793 AT read OK    6 "\r\nOK\r\n"
   878.793 AT send      11 "AT+CGREG?\r\n"
   878.825 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   878.826 AT read OK    6 "\r\nOK\r\n"
   893.830 AT send      10 "AT+CREG?\r\n"
   893.861 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   893.868 AT read OK    6 "\r\nOK\r\n"
   893.868 AT send      11 "AT+CGREG?\r\n"
   893.900 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   893.901 AT read OK    6 "\r\nOK\r\n"
   908.905 AT send      10 "AT+CREG?\r\n"
   909.390 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   909.392 AT read OK    6 "\r\nOK\r\n"
   909.392 AT send      11 "AT+CGREG?\r\n"
   909.424 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   909.432 AT read OK    6 "\r\nOK\r\n"
   924.436 AT send      10 "AT+CREG?\r\n"
   924.467 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   924.475 AT read OK    6 "\r\nOK\r\n"
   924.475 AT send      11 "AT+CGREG?\r\n"
   924.507 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   924.508 AT read OK    6 "\r\nOK\r\n"
   939.512 AT send      10 "AT+CREG?\r\n"
   939.543 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   939.554 AT read OK    6 "\r\nOK\r\n"
   939.554 AT send      11 "AT+CGREG?\r\n"
   939.586 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   939.587 AT read OK    6 "\r\nOK\r\n"
0000939588 [system] WARN: Resetting WLAN due to WLAN_WD_TO()
   939.588 AT send       4 "AT\r\n"
   939.617 AT read OK    6 "\r\nOK\r\n"
   939.617 AT send      12 "AT+CPWROFF\r\n"
   939.769 AT read OK    6 "\r\nOK\r\n"
   941.079 AT send       4 "AT\r\n"
   941.222 AT read UNK   3 "AT\r"
   941.223 AT read OK    6 "\r\nOK\r\n"
   941.223 AT send       9 "AT+CGMM\r\n"
   941.256 AT read UNK   8 "AV+CGMM\r"
   941.257 AT read UNK  13 "\r\nSARA-G350\r\n"
   941.258 AT read OK    6 "\r\nOK\r\n"
   941.459 AT send       6 "ATE0\r\n"
   941.491 AT read UNK   5 "A\xd4E0\r"
   941.492 AT read OK    6 "\r\nOK\r\n"
   941.492 AT send      11 "AT+CMEE=2\r\n"
   941.524 AT read OK    6 "\r\nOK\r\n"
   941.524 AT send      19 "AT+CMER=1,0,0,2,1\r\n"
   941.557 AT read OK    6 "\r\nOK\r\n"
   941.557 AT send      15 "AT+IPR=115200\r\n"
   941.589 AT read OK    6 "\r\nOK\r\n"
   941.689 AT send      10 "AT+CPIN?\r\n"
   941.725 AT read ERR  37 "\r\n+CME ERROR: operation not allowed\r\n"
   942.282 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   942.726 AT send      10 "AT+CPIN?\r\n"
   942.758 AT read  +   16 "\r\n+CPIN: READY\r\n"
   942.760 AT read OK    6 "\r\nOK\r\n"
   942.760 AT send       9 "AT+CGSN\r\n"
   942.794 AT read UNK  19 "\r\n359315075381268\r\n"
   942.797 AT read OK    6 "\r\nOK\r\n"
   942.797 AT send       9 "AT+CGMI\r\n"
   942.830 AT read UNK  10 "\r\nu-blox\r\n"
   942.831 AT read OK    6 "\r\nOK\r\n"
   942.831 AT send       9 "AT+CGMR\r\n"
   942.863 AT read UNK   9 "\r\n08.70\r\n"
   942.864 AT read OK    6 "\r\nOK\r\n"
   942.864 AT send       6 "ATI9\r\n"
   942.899 AT read UNK  16 "\r\n08.70,A00.02\r\n"
   942.900 AT read OK    6 "\r\nOK\r\n"
   942.900 AT send       9 "AT+CCID\r\n"
   942.934 AT read  +   30 "\r\n+CCID: My ICCID\r\n"
   942.945 AT read OK    6 "\r\nOK\r\n"
   942.945 AT send      11 "AT+CMGF=1\r\n"
   942.978 AT read OK    6 "\r\nOK\r\n"
   942.978 AT send      13 "AT+CNMI=2,1\r\n"
   943.011 AT read OK    6 "\r\nOK\r\n"
   943.011 AT send       9 "AT+CIMI\r\n"
   943.045 AT read UNK  19 "\r\n214074303246741\r\n"
   943.046 AT read OK    6 "\r\nOK\r\n"
   943.046 AT send      13 "AT+COPS=3,2\r\n"
   943.080 AT read OK    6 "\r\nOK\r\n"
   943.080 AT send      11 "AT+UPSV=1\r\n"
   943.112 AT read OK    6 "\r\nOK\r\n"
0000943113 [system] INFO: Sim Ready
0000943114 [system] INFO: ARM_WLAN_WD 1
   943.113 AT send      12 "AT+CGREG=2\r\n"
   943.145 AT read OK    6 "\r\nOK\r\n"
   943.145 AT send      11 "AT+CREG=2\r\n"
   943.178 AT read OK    6 "\r\nOK\r\n"
   943.178 AT send      10 "AT+CREG?\r\n"
   943.210 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   943.212 AT read OK    6 "\r\nOK\r\n"
   943.212 AT send      11 "AT+CGREG?\r\n"
   943.245 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   943.254 AT read OK    6 "\r\nOK\r\n"
   943.254 AT send      10 "AT+URAT?\r\n"
   943.289 AT read ERR  23 "\r\n+CME ERROR: unknown\r\n"
   943.289 AT send      10 "AT+CREG?\r\n"
   943.322 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   943.323 AT read OK    6 "\r\nOK\r\n"
   943.323 AT send      11 "AT+CGREG?\r\n"
   943.356 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   943.357 AT read OK    6 "\r\nOK\r\n"
   948.890 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   948.893 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   958.361 AT send      10 "AT+CREG?\r\n"
   958.464 AT read  +   14 "\r\n+CREG: 2,0\r\n"
   958.465 AT read OK    6 "\r\nOK\r\n"
   958.465 AT send      11 "AT+CGREG?\r\n"
   958.497 AT read  +   15 "\r\n+CGREG: 2,2\r\n"
   958.498 AT read OK    6 "\r\nOK\r\n"
   962.566 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   963.507 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   964.449 AT read  +   14 "\r\n+CIEV: 2,0\r\n"
   964.850 AT read  +   12 "\r\n+CREG: 3\r\n"
   964.853 AT read  +   13 "\r\n+CGREG: 3\r\n"
   964.855 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   964.857 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   964.858 AT read  +   13 "\r\n+CGREG: 0\r\n"
   964.860 AT read  +   14 "\r\n+CIEV: 9,1\r\n"
CIEV matched: 9,1
   973.502 AT send      10 "AT+CREG?\r\n"
   973.533 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   973.535 AT read OK    6 "\r\nOK\r\n"
   973.535 AT send      11 "AT+CGREG?\r\n"
   973.567 AT read  +   15 "\r\n+CGREG: 2,0\r\n"
   973.569 AT read OK    6 "\r\nOK\r\n"
   977.368 AT read  +   14 "\r\n+CIEV: 2,1\r\n"
   977.371 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   977.373 AT read  +   13 "\r\n+CGREG: 3\r\n"
   977.374 AT read  +   14 "\r\n+CIEV: 9,0\r\n"
CIEV matched: 9,0
   988.573 AT send      10 "AT+CREG?\r\n"
   988.604 AT read  +   14 "\r\n+CREG: 2,3\r\n"
   988.606 AT read OK    6 "\r\nOK\r\n"
   988.606 AT send      11 "AT+CGREG?\r\n"
   988.638 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
   988.647 AT read OK    6 "\r\nOK\r\n"
  1003.651 AT send      10 "AT+CREG?\r\n"
  1003.737 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1003.744 AT read OK    6 "\r\nOK\r\n"
  1003.744 AT send      11 "AT+CGREG?\r\n"
  1003.776 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1003.777 AT read OK    6 "\r\nOK\r\n"
  1018.781 AT send      10 "AT+CREG?\r\n"
  1018.812 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1018.823 AT read OK    6 "\r\nOK\r\n"
  1018.823 AT send      11 "AT+CGREG?\r\n"
  1018.855 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1018.856 AT read OK    6 "\r\nOK\r\n"
  1033.860 AT send      10 "AT+CREG?\r\n"
  1034.149 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1034.157 AT read OK    6 "\r\nOK\r\n"
  1034.157 AT send      11 "AT+CGREG?\r\n"
  1034.189 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1034.190 AT read OK    6 "\r\nOK\r\n"
  1049.194 AT send      10 "AT+CREG?\r\n"
  1049.225 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1049.236 AT read OK    6 "\r\nOK\r\n"
  1049.236 AT send      11 "AT+CGREG?\r\n"
  1049.268 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1049.269 AT read OK    6 "\r\nOK\r\n"
  1064.273 AT send      10 "AT+CREG?\r\n"
  1064.304 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1064.316 AT read OK    6 "\r\nOK\r\n"
  1064.316 AT send      11 "AT+CGREG?\r\n"
  1064.348 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1064.349 AT read OK    6 "\r\nOK\r\n"
  1079.353 AT send      10 "AT+CREG?\r\n"
  1079.384 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1079.386 AT read OK    6 "\r\nOK\r\n"
  1079.386 AT send      11 "AT+CGREG?\r\n"
  1079.418 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1079.419 AT read OK    6 "\r\nOK\r\n"
  1094.423 AT send      10 "AT+CREG?\r\n"
  1094.882 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1094.890 AT read OK    6 "\r\nOK\r\n"
  1094.890 AT send      11 "AT+CGREG?\r\n"
  1094.922 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1094.923 AT read OK    6 "\r\nOK\r\n"
  1109.927 AT send      10 "AT+CREG?\r\n"
  1109.958 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1109.969 AT read OK    6 "\r\nOK\r\n"
  1109.969 AT send      11 "AT+CGREG?\r\n"
  1110.001 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1110.002 AT read OK    6 "\r\nOK\r\n"
  1125.006 AT send      10 "AT+CREG?\r\n"
  1125.484 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1125.491 AT read OK    6 "\r\nOK\r\n"
  1125.491 AT send      11 "AT+CGREG?\r\n"
  1125.523 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1125.524 AT read OK    6 "\r\nOK\r\n"
  1140.528 AT send      10 "AT+CREG?\r\n"
  1140.559 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1140.566 AT read OK    6 "\r\nOK\r\n"
  1140.566 AT send      11 "AT+CGREG?\r\n"
  1140.598 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1140.599 AT read OK    6 "\r\nOK\r\n"
  1155.603 AT send      10 "AT+CREG?\r\n"
  1155.634 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1155.646 AT read OK    6 "\r\nOK\r\n"
  1155.646 AT send      11 "AT+CGREG?\r\n"
  1155.678 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1155.679 AT read OK    6 "\r\nOK\r\n"
  1170.683 AT send      10 "AT+CREG?\r\n"
  1170.714 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1170.725 AT read OK    6 "\r\nOK\r\n"
  1170.725 AT send      11 "AT+CGREG?\r\n"
  1170.757 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1170.758 AT read OK    6 "\r\nOK\r\n"
  1185.762 AT send      10 "AT+CREG?\r\n"
  1185.793 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1185.805 AT read OK    6 "\r\nOK\r\n"
  1185.805 AT send      11 "AT+CGREG?\r\n"
  1185.837 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1185.838 AT read OK    6 "\r\nOK\r\n"
  1200.842 AT send      10 "AT+CREG?\r\n"
  1200.987 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1200.995 AT read OK    6 "\r\nOK\r\n"
  1200.995 AT send      11 "AT+CGREG?\r\n"
  1201.027 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1201.028 AT read OK    6 "\r\nOK\r\n"
  1216.032 AT send      10 "AT+CREG?\r\n"
  1216.351 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1216.352 AT read OK    6 "\r\nOK\r\n"
  1216.352 AT send      11 "AT+CGREG?\r\n"
  1216.384 AT read  +   15 "\r\n+CGREG: 2,3\r\n"
  1216.392 AT read OK    6 "\r\nOK\r\n"
  1231.396 AT send      10 "AT+CREG?\r\n"
  1231.427 AT read  +   14 "\r\n+CREG: 2,3\r\n"
  1231.435 AT read OK    6 "\r\nOK\r\n"
  1231.435 AT send      11 "AT+CGREG?\r\n"
Serial connection closed.
I also successfully did
particle device doctor
and restarted the device. It goes shortly to breathing white, then blue and starts always blinking GREEN non stop
Hi @animal-navigation - this device is really struggling.
At first, it desperately struggles to find a tower,
and upon doing so after some time, it is rejected.
The device’s SIM appears ok.
Towers often reject devices with very poor signal just because the registration process hangs. Can you run the Carrier scan application in Cloud Debug?
@Gorgo - we do not recommend de-/reattaching antennas to running Electrons because the transmitter in the modem is not intended to be operated with no load. This won’t necessarily force an issue, but is regardless not a recommended practice.
Hi @marekparticle
Thanks for the tip.s The cellular signal is not great at my office (maybe 3 of 5 bars) but it is not zero and I tried a new device which can connect but the ones I unplugged and re-attached antennas as they were active cant find mobile towers even with the same antenna.
By running the Carrier scan application do you mean this
Could you elaborate on
"Reset the Electron and immediately open the particle serial monitor.
The Electron will breathe white. Tap the MODE button once and a carrier scan will begin. You must do this within the first 10 seconds of startup otherwise the normal tests will be done. "
By Reset it means tap once and short the Reset button? Any more detailed guidance?
Maybe it's also worth approaching any cellular tower to be able to have strong signal in the antenna to recover from ever green LED blinking?
@marekparticle
I have also done
and it went successfully but did not solve the issue. Is there any other full factory reset procedure to start over and solve the issue by full reset?
  • Reset means hit the Reset button or un/re-power the device.
  • Yes, it’s worth to be sure that you have strong signal before proceeding. A Carrier Scan is a good way of evidencing suspicion of signal issues.
Again, the logs bear out a situation of weak signal (given the time spent looking for a tower and ultimate rejection therefrom), so it’s unlikely that a firmware change would do anything here. Cell phone service is not a reliable indicator of service available to Particle devices.
I always use:
particle update
and
in CLI as a reset mechanism, but that’s not my best bet.
I’m really curious about these other devices - is it true that all devices whose antennas have been un/plugged while running have this issue? That strikes me as a potential culprit here.
One other comment about disconnecting/reconnecting the antenna – the U.FL connector is not designed to be disconnected/reconnected over and over – the total number of cycles is something like 30 (!). And you really need to exercise care each time. Sparkfun has some tips here: https://learn.sparkfun.com/tutorials/three-quick-tips-about-using-ufl/all
Oh that’s really good to know! I was quite repetitive and maybe brutal with the device which now has lower signal strength comparing to a fresher device with less reconnect cycles
@marekparticle
Turned out that the trouble device started working when is in geographically closer to the o2 tower (the Particle cellular provider in the UK). It started being patchy in my office though. Another more fresh device (activated last week) is receiving signal in my office with the same antenna. My hypothesis for now is not that the single act of un- and re-plugging an antenna on a working device was NOT the cause of the any software glitch but it was rather the physical micro-damages of u.fl connector after multiple un- and re-plugging. The latter might have caused lower signal strength in the GPS module and the system started receiving cellular signal just under the threshold when the tower/device refuse to establish connection. This is my working hypothesis for now
The lessons from here are as follows:
  1. test devices in a physical proximity to a serving cell tower
  2. reduce the number of replugging u.fl antenna cycles and do it only when absolutely necessary
The topic is not very fresh, but I though I would join, thus I noticed the very same problem. It happens that electron is stuck in the registration phase blinking green and blue indefinitely. Reseting nor power cycling device does not help. However, flashing tinker helps! With fresh tinker onboard electron registers immediately. RSSI is pretty good - 70dBm. Don’t have a slightest clue here. I would appreciate any ideas.
I’m using 3rd party MVNO. Electron is running 2.0.0.
