So i am currently using this code to detect lat and long from my adafruit gps (https://blog.particle.io/2019/05/17/learn-how-to-build-this-cellular-asset-tracker-with-a-particle-boron/). However the current code has OLED. for my use case i do not need an OLED on my tracker. Can someone help and tell me which code to remove just to keep the necessary code to get updates on my Lat and long. -ps: i tried editing the code and removing anything related to the OLED but i did not work! it flashed but i can find the lat or long in my events console!!
// dependencies.AssetTrackerRK=0.1.7
// dependencies.oled-wing-adafruit=0.0.5
// Port of TinyGPS for the Particle AssetTracker
// https://github.com/mikalhart/TinyGPSPlus
#include "TinyGPS++.h"
#include "oled-wing-adafruit.h"
SYSTEM_THREAD(ENABLED);
This sample sketch demonstrates the normal use of a TinyGPS++ (TinyGPSPlus) object directly.
void displayInfo(); // forward declaration
const unsigned long PUBLISH_PERIOD = 15000;
const unsigned long SERIAL_PERIOD = 5000;
const unsigned long MAX_GPS_AGE_MS = 10000; // GPS location must be newer than this to be considered valid
// The TinyGPS++ object
TinyGPSPlus gps;
unsigned long lastSerial = 0;
unsigned long lastPublish = 0;
unsigned long startFix = 0;
bool gettingFix = false;
OledWingAdafruit display;
// The GPS module on the AssetTracker is connected to Serial1 and D6
Serial1.begin(9600);
// Settings D6 LOW powers up the GPS module
pinMode(D6, OUTPUT);
digitalWrite(D6, LOW);
startFix = millis();
gettingFix = true;
display.setup();
display.clearDisplay();
display.display();
display.loop();
while (Serial1.available() > 0) {
if (gps.encode(Serial1.read())) {
displayInfo();
void displayInfo()
if (millis() - lastSerial >= SERIAL_PERIOD) {
lastSerial = millis();
char buf[128];
char pubbuf[120];
if (gps.location.isValid() && gps.location.age() < MAX_GPS_AGE_MS) {
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(0,0);
snprintf(buf, sizeof(buf), "%f", gps.location.lat());
display.println(buf);
snprintf(buf, sizeof(buf), "%f", gps.location.lng());
display.display();
snprintf(buf, sizeof(buf), "%f,%f,%f", gps.location.lat(), gps.location.lng(), gps.altitude.meters());
snprintf(pubbuf, sizeof(pubbuf), "{\"position\": {\"value\":1, \"context\":{\"lat\": \"%f\", \"lng\": \"%f\"}}}", gps.location.lat(), gps.location.lng());
Serial.println(pubbuf);
if (gettingFix) {
gettingFix = false;
unsigned long elapsed = millis() - startFix;
Serial.printlnf("%lu milliseconds to get GPS fix", elapsed);
else {
strcpy(buf, "no location");
if (!gettingFix) {
gettingFix = true;
display.setTextSize(1);
display.println("no fix");
display.display();
Serial.println(buf);
if (Particle.connected()) {
if (millis() - lastPublish >= PUBLISH_PERIOD) {
lastPublish = millis();
Particle.publish("gps", pubbuf, PRIVATE);
