Google Cloud Integration - Receiving Events
I know that the particle cloud/console has the google cloud pub/sub integration. I set this up accordingly, and it worked great for sending data, publishing it to a topic.
However, the provided code to receive events sent to the topic doesn’t seem to work, and all the info I find online is about sending data, not receiving.
Is there something more that needs to happen? Do I need to create a subscription with a certain naming convention? To be clear, the integration documentation shows that this code should work (i think):
  // Subscribe to the integration response event
  Particle.subscribe("hook-response/<topicname>", myHandler, MY_DEVICES);
void myHandler(const char *event, const char *data) {
  // Handle the integration response
Any and all help and advice is appreciated!
Do you see the response in console at all?
You can’t receive events sent to a topic using the Google cloud pubsub integration. It’s one way from the Particle device to Google Cloud.
That bit of code gets the result from publishing an event from a device. It essentially is the result code from a publish that triggers a Google cloud pubsub integration, not the actual pubsub topic.
You could use a Google Cloud function to subscribe to a pubsub message and then generate a Particle.publish using the particle-api-js.
That makes a ton of sense! Thanks!
