The network(s) I use at home have passwords that are 36 characters long. Neither Smart Config nor USB connection will accept them. Is there any workaround, or do I have to go somewhere else to tinker with spark cores (or change the password for every one of the N other connected devices in the house)?
Hey @paul314,
After some extra research on this, it looks like a limitation on the CC3000 itself:
http://processors.wiki.ti.com/index.php/CC3000_Release_Notes
It looks like Adafruit also ran into this issue here:
https://github.com/adafruit/Adafruit_CC3000_Library/issues/4
Iâm guessing you thought of this, but some access points will let you run multiple SSIDs which might be another workaround. Iâm hoping new versions of the CC3000 driver will allow for longer keys.
David
Oh, well. Down another rabbit hole. Thanks for the quick answer!
(I hadnât thought of multiple SSIDS â all I need for that is to throw away all my current router and access point hardwareâŚ)
Zyxel X-550 for a router in the basement, supplemented with a little Trendnet access point where the Zyxel runs out of range. The zyxel is lucky if it can do one SSIDâŚ
Ran into the same issue, and was guessing that it was a password length issue. Mine is 63 characters. I like your workaround, and will give it a try.
I got the same issue with my long password. My AP does not support multiple SSIDs, but I wrote a very simple patch to enable USB setup for WPA passwords longer than 32 characters (Smart Config is limited to 32 characters by CC3000 specs). My spark core is now connected to my network.
Link to the corresponding pull request: https://github.com/spark/core-firmware/pull/61
A compiled version (that you can flash with dfu-util) is available here on my fork: https://github.com/dvinc/core-firmware/releases/tag/long-wifi-passwords
Thanks for the pull request @dvince!
Thanks! Will give it a try.
Any idea when this fix might make it out into the wild? I am currently using a guest zone / SSID for my cores, but that is ugly.
Ken
Thanks for the bump on this thread, looks like this got lost waiting on the CLA, checking with the firmware team to see if we can merge this asap.
David
Same issue here. If/when this patch is released, will I be able to use my very long wifi password with the spark core at that point? Does it somehow get around the chipâs 32-character limit?
Also, any very rough idea if/when this may be released, so I know if I should just wait it out or find another way around it? Thanks!
This patch was merged 4 months ago.
Did you try using with a password longer than 32 characters?
Yes, my password has about 50 characters. The Android spark app gives a pop up with âThe Spark Core can only accept passwords up to 32 charactersâ Is that no longer supposed to happen? Did the patch have a way to work around the chipâs 32-character limit?
You canât use a password longer than 32 characters from the apps, because Smart Config is limited to 32 characters (this is defined within the CC3000 firmware, and not under our control). You can, however, set a password longer than 32 characters using the USB setup method. The easiest way to do that these days is with the command line tool. If you have Node.js installed:
npm install -g spark-cli
and then
spark setup
This should be done when your Spark Core is connected to your computer over USB and is in listening mode (flashing blue).
Hope that helps!
Thanks for the help Zach! I installed Node and ran the setup. After entering my SSID and password, it flashes green for awhile (while the spark setup is telling me to wait for breathing cyan), but then reverts to flashing blue. If I hit enter at this point, it says âDevice is not connectedâ.
I tried a reset via holding both buttons, then only mode button, and repeating the process with the same results.
I also wonder if using this method with nodejs rather than the app will cause any limitations of the use of the core? I ask because I do not understand how the app being limited to the CC3000 firmware relates to using node to set the password to somehow get around this issue. If the CC3000 is the chip that should be connecting via wifi, and it is limited to 32 characters, how does setting the password via another interface allow it to connect using a longer password? Iâm clearly missing something
Good question!
The original password length limitation was also enforced on the mobile apps in that they would prevent you supplying a longer password. When you use the serial / CLI interface to the core, youâre entering your wifi credentials directly into the firmware on the core, bypassing the mobile restriction. The latest version of the firmware handles longer passwords better than earlier versions and should work well with the CC3000.
I hope that helps!
David
What does this LED behaviour indicate during the set up process?
never encountered this but maybe an invalid wifi profile?
