Hello,
I have a program with a void function that gets 3 strings from “http request”. I want to send them to the main function, void loop. I tried to make global strings by declaring them in the beginning, but the compiler doesn’t recognize them in the void function. What can I do, how can I send them to the loop function?
Itay
@itayd100, can you post your code please.
Hey @peekay123,
This is the code:
#include "HttpClient/HttpClient.h"
//button
int button = D6;
int i=0;
//LEDs
int RedLED = A4;
int GreenLED = A5;
int BlueLED = A6;
//parameters
String num1;
String lat;
String lon;
String city;
HttpClient http;
http_header_t headers[] = {
// { "Content-Type", "application/json" },
// { "Accept" , "application/json" },
{ "Accept" , "*/*"},
{ NULL, NULL }
http_request_t request;
http_response_t response;
//while(!Serial.available()) SPARK_WLAN_Loop();
delay(5*1000);
Serial.println("Hello!");
//PINs SET
pinMode(RedLED, OUTPUT);
pinMode(GreenLED, OUTPUT);
pinMode(BlueLED, OUTPUT);
pinMode(button, INPUT_PULLDOWN);
if (!digitalRead(button))
Serial.println(i);
IP_LOC();
i++;
Serial.print(lat);
Serial.print(lon);
Serial.print(city);
void IP_LOC(){
//reset the LEDS
digitalWrite(RedLED, LOW);
digitalWrite(GreenLED, LOW);
digitalWrite(BlueLED, LOW);
Serial.println("Asking IP LOC ");
delay(500);
request.hostname = "ip-api.com";
request.port = 80;
request.path = "/json/?callback=yourfunction" ;
// Get request
http.get(request, response, headers);
String raw_response(response.body);
String str=raw_response;
int temp = str.indexOf("lat");
lat = raw_response.substring(temp+5,temp+5+6); //the place of the number.
Serial.println(lat);
temp = str.indexOf("lon");
lon = raw_response.substring(temp+5,temp+5+6); //the place of the number.
Serial.println(lon);
temp = str.indexOf("\"city\"");
int temp2 = str.indexOf(",\"country\":");
//Serial.println(temp);
city = raw_response.substring(temp+8,temp2-1); //the place of the number.
Serial.println(city);
Can you also post the error message the compiler throws.
I guess it’s not that the compiler doesn’t know your variables, but it doesn’t like how you use them.
But we can only be certain when seeing the compiler messages
Hey @ScruffR,
Yes, I know it’s me (I hear it from my girlfriend too ;-))
This is the error:
undefined reference to `String::operator=(String&&)'
As I guessed
Try this
lat = "" + raw_response.substring(temp+5,temp+5+6);
// or this
lat = raw_response.substring(temp+5,temp+5+6).c_str();
It’s not nice, but it should work. It’s a known bug of the String class
The message tells you that the var was recognized as String, but there is no assignment operator that can take a String as r-value (source).
So it’s not you - we are just never understood right
