I’ve got two global variables, defined before the setup()/loop():
bool loopState = true;
String loopParam = "KR,010,05,01,330000";
Spark.function("route", route);
Then I’ve got a route-function:
int route(String command){
String prefix = command.substring(0,2);
String params = command.substring(3);
if(prefix == "LO"){ //LOOP STATUS
loopState = (command.substring(3,4)=="0")?false:true; // This DOES work
loopParam = command.substring(5); // This DOES NOT work (Line 50)
loopParam = "KR,010,05,01,FF00FF"; // This DOES work
}else if(prefix == "KR"){
postKnightRider(params);
THe problem I have, is that when I try to assign something to the variable loopParam.
When I assign it maually (see the line that works), everything works, and the global variable has the new string.
However, when I want to use the command.substring(5) method, I get an error:
neopixel-notification.o: In function `route(String)':
/spark/compile_server/shared/workspace/3_compile-server2/core-firmware/build/neopixel-notification.cpp:50: undefined reference to `String::operator=(String&&)'
make: *** [ff8a3c9844850d1cea5b32d0486d42a57ce6b45aa3d870fe4c05f7598afc.elf] Error 1
Does anyone know a workaround to this?
