Hi !
I defined a char* variable and declare it in the cloud, like this
char* rgb = "0;0;0";
void setup(){
Spark.variable("rgb", rgb, STRING);
Spark.subscribe("upColor", colorUpdate);
When the event upColor is published, this is what happened
void colorUpdate(const char *event, const char* data){
rgb = strdup(data);
// rgb = "10;10;10"; Doesn't work
I want to copy ‘data’ into ‘rgb’, but the value stay at “0;0;0” and is not updated. Even if I used the second line…
What’s wrong with my code ??
Thank you
You want to declare your string like this
char rgb[16] = "0;0;0";
Otherwise it will just be a pointer pointing to flash memory (unchangable) and this address will be stored in your Spark.variable().
Later when you reassign the pointer to a new string (location), your Spark.variable() won’t follow.
If you do it as above, you get a pointer in RAM and when updating the string, you can copy your new content there and hence the Spark.variable() will “see” the new content.
BTW: I wouldn’t use strdup() but sprintf() or strcpy()
It works with the char array, thank you
