Hi all, I seem to be having some trouble calling functions inside void loop{} instead of defining all my functionality inline. I was thinking these functions would really streamline my main code, and so far they have, but for some reason whenever I flash this firmware (or some variant thereof), I seem to get stuck in some loop which renders the Spark unresponsive to the cloud, meaning I can’t re-flash firmware. I have a feeling I’m going to get very sick of resetting the WiFi on this thing so I’d like to know what I’m doing wrong!
Previously, I had seen behavior like this with my clockcontrol.ino program, which I just copy-pasted in as a function, void clockcontrol(). So, I know that code on its own is fine, but in the clockcontrol.ino program, I didn’t create a function - all the code was just inline.
Note that the code below has some strange variables like “panicstatus”; don’t worry about that, it’s for another function that I chose not to include because it didn’t seem important to the discussion (removing it from void loop{} didn’t change the behavior).
#include "SparkTime/SparkTime.h"
UDP UDPClient;
SparkTime rtc;
int status = D0;
int correction = D1;
unsigned long unix;
int panicstatus = 0;
char tweet;
TCPClient client;
byte server[] = { 1, 1, 1, 1 }; // server
pinMode(correction, OUTPUT);
digitalWrite(correction, LOW);
pinMode(status, OUTPUT);
rtc.begin(&UDPClient, "north-america.pool.ntp.org");
rtc.setTimeZone(-7); // gmt offset
unix = updateunix(); // update unix time from NTP
if(panicstatus==0)
if(rtc.second(unix)%2) // flash D0 every other second
digitalWrite(status, HIGH);
else
digitalWrite(status, LOW);
clockcontrol(); // function defined below
if(rtc.minute(unix)%5) // part of an implementation I'm working on with Twitter
sendgetrequest(); // GET from the server
tweet = latesttweet(); // eventually this will read in text from the server to an array or string
int updateunix() // update unix time from NTP
int u = rtc.now();
return u;
void clockcontrol() // analog clock time setting function
unix = rtc.now();
if(((rtc.second(unix)>=57 && rtc.minute(unix)==57) || (rtc.second(unix)<=3 && rtc.minute(unix)==58)) && (rtc.hour(unix)!=6 && rtc.hour(unix)!=18))
digitalWrite(correction, HIGH);
unix = rtc.now();
if(((rtc.second(unix)>=57 && rtc.minute(unix)==57) || (rtc.second(unix)<=7 && rtc.minute(unix)==58)) && (rtc.hour(unix)==6 || rtc.hour(unix)==18))
unix = rtc.now();
else digitalWrite(correction, LOW);
unix = rtc.now();
void sendgetrequest() // connect to server
if (client.connect(server, 8081))
Serial.println("connected");
client.println("GET /tweets.txt");
client.println("Host: 1.1.1.1");
client.println("Content-Length: 0");
client.println();
else
panicstatus = 1;
char latesttweet() // read in latest text from server (work in progress)
if (client.available())
char t;
t = client.read();
panicstatus = 0;
return t;
if (!client.connected())
panicstatus = 2;
client.stop();
for(;;);
Dan
