Getting Cellular Data Usage for Boron
I’m running into problems with getting cellular data usage for the Boron. I’ve written the following example application:
// Logging
SerialLogHandler logHandler(LOG_LEVEL_ALL);
// Particle system stuff
SYSTEM_THREAD(ENABLED);
    uint32_t freeMem = System.freeMemory();
    Log.info("Free memory: %ld", freeMem);
    if (Cellular.ready())
        CellularData data;
        if (!Cellular.getDataUsage(data))
            Log.error("Error! Not able to get data.");
        else
            Log.info("CID: %d SESSION TX: %d RX: %d TOTAL TX: %d RX: %d",
                     data.cid,
                     data.tx_session, data.rx_session,
                     data.tx_total, data.rx_total);
            Serial.println(data); // Printable
        CellularSignal sig = Cellular.RSSI();
        Log.info("Cell quality: %d (%d)\n", sig.qual, sig.rssi);
    else
        Log.info("Cell not ready yet...\n");
    delay(5000);
getDataUsage always returns an error. I get the following output:
0000116280 [app] INFO: Free memory: 64200
0000116281 [app] ERROR: Error! Not able to get data.
0000116428 [app] INFO: Cell quality: 31 (27)
0000121429 [app] INFO: Free memory: 64200
0000121431 [app] ERROR: Error! Not able to get data.
0000121578 [app] INFO: Cell quality: 31 (27)
I haven’t been able to get any data from Cellular.getDataUsage. Am I missing something?
me too,
¿did you solve it?
I can’t help with Cellular.getDataUsage , but you can check the daily usage through the Web API
[copy/paste from another thread]
You can easily track daily cellular data with:
https://api.particle.io/v1/sims/XXXX/data_usage?access_token=YYYY
Where:
XXXX= Electron’s ICCID (go to Console.particle.io , View Device)
YYYY = Personal Access Token (go to Build.particle.io, Settings)
Bookmark the link once you add your credentials and you can check daily usage quickly.
Nice one.
Does this work for the Boron LTE devices?
The u-blox SARA-R410M-02B modem in the Boron LTE, E Series LTE, and Electron LTE does not support the commands used to implement getDataUsage and setDataUsage so they do not work on LTE devices. This is missing in the docs; I’ll add it next week.
How about the Boron 2G/3G? That’s the board that I’m having troubles with. I’m on DeviceOS v1.2.1 so I’m hoping v1.4.0 fixes this issue. I haven’t had a chance to try it yet.
