If you were to attempt to recreate any of the examples of sending co-ordinate data to Ubidots, they seem to have broken or changed something. Existing implementations still work, but create a new dashboard add a map widget for a device you already know is sending valid data and hey presto the widget will claim it has no data to display. The main difference seems to be the add map widget process no longer asks which variable the location context has been added to. I can’t seem to find any documentation on a change, everything should apparently still work the way it always has, but clearly not.
Just a heads up…
