Is it possible to control the functioning of one pin by tinker when the other pin is programmed with particle build ?
I found an error while trying to do so in tinker .
I’m not quite sure what you mean there, but you can adapt the tinker firmware to keep what you want and add whatever functionality you need.
If you can elaborate a bit more?
There is also this thread
Help appending code to the Tinker Firmware for Photon
