Fresh coat of paint on Console 🖌️
When using multiple monitors and the event log is on the right one and I mouse to the left screen, it holds onto the popout, blocking the events.
I think auto-hiding it would be best but also I think I would prefer if it would just resize the rest of the content to the right of it instead of covering up the name of an event. Especially because the "more info" event section pretty much just only adds the firmware version and uses 1/3 of the screen.
Hey, even if you AVOID the area of the side panel with your mouse?
If you leave the right monitor, can you make sure your mouse moves over the url bar and not the side panel? (like following my red line on the previous picture).
I see from other posts you are using Firefox, I wonder if that is different. At least on Chrome this workaround works (for me).
I mean yeah I can avoid it if I need it to be seen but I'm just agreeing that it's not ideal. It works if I pan over the top or bottom but it could just be set to resize when the window loses focus too.
Add us to the list that wastes so much time with dark mode forced on us. You copy text from the console and paste into anything that recognizes styles and the text is white and you can't see it. Really?! This is bugging the daylights out of us. At least give us a choice because in this case it is a really stupid change.
