I have this I2C driver pretty much finished now, and have completed a pretty extensive testing process. @timb, if you think this will be of help to you I’m more than willing to send you the code. It’s “C” not “C++” and not compatible with the spark wiring API. However, it does use interrupts and DMA and seems to work fairly well. Probably easy enough to steal from or put a Spark wrapper around.
In my testing, I got BERR (bus errors) at 1000 KHz. 800 KHz works fine with no problems. Adafruiit has 10K pull-ups on the breakout and that’s not much when its the only device on the bus. I’ve found from past experience you need a effective total resistance of around 1200 ohms for good clean clocks. Whether it’s the pull-ups that caused the problem I don’t know. At twice the nominal maximum, 800 KHz is pretty good.
I have the Adafruit SPI 8K FRAM running under my OS utilizing a new SPI driver that uses DMA and interrupts. I’m running it at the maximum SPI clock speed the STM32F103 supports, 18 MHz. It took 138 milliseconds to read 256K bytes of data using a 256 byte buffer. This translates to a smidgen under 2 megabytes (16 megabits) per second. Could probably get the rate above 2 mbytes by using a bigger buffer.
@pra, NICE!! I had it on my list to do add DMA SPI to the Core but you are there already! Can you a) Share the code and b) make the DMA stuff into a pull request?
Although this runs on a Spark Core, it doesn’t work with the Spark firmware. It’s probably possible to retrofit, but would require some workarounds for the mutex, message queues and memory management features I use from CoOS. I can send you the file if you want to take a look.
If you send me a PM with your email address, I’ll send you the files. It would be easier to make my SPI driver work for SPI than adapt the I2C one. I also incorporated things you talked about back aways, such as setting speed and mode for each transaction so you can easily access multiple SPI devices. I support up to 8 concurrent devices. There is little value in DMA using the single byte at a time interface that wiring utilizes, so an additional SPI API that does block transfers is probably the way to go.
Okay guys, I have preliminary DMA working with I2C! Well, at least for reads. I’m having some write issues but should be able to clean that up shortly. The reads are occasionally returning bad data, so I think I’ve got a rouge pointer somewhere.
I’m also changing Spark’s Wire library a bit to make it more compatible with existing Arduino libraries. In addition to that I’m implementing a spark.I2C() mini-library that will give you lower level access to stuff.
@peekay123 I suggest you add a spark.SPI component like @pra suggested.
@timb, I am just starting to look at the SPI stuff. I will wait to see your code to make sure everything meshes and I will follow your lead on the spark. stuff.
