Flow to onboard new Muons
Hey,
I want to onboard a brand new Muon into an existing product and I want it to remain unclaimed.
The intro to products tell me to:
  1. Add Devices to
  2. Initial Device Setup
  3. Device and Claiming
  4. Development Workflow
On the other hand, the Manufacturing procedure tells us to activate the SIM:
  1. SIM Activation
    But it mentions to do so in the case:
    If the manufacturer’s desired flow involves activating each individual SIM just prior to manufacturing, without adding the device to your product, you can use the following setup flow.
Questions:
1- Do we need to activate the SIM as stated in the Manufacturing process?
2- Or does the fact of adding the device to a product activates the SIM as well?
Adding the device to the product is all you need to do.
(Except on the Electron 1 with a 4FF plastic SIM card instead of a built-in MFF2 SMD SIM. Plastic SIM cards are not associated with the device when it is manufactured so they can't be activated by adding the device to the product.)
