So haven’t been messing with stuff for awhile but decided to whip up a nightlight for the little one and while trying to get things working just the way I want I have noticed that only rarely is the new firmware making it onto the Photon. No SOS or anything like that happening. Dashboard says it flashed and I saw the magenta flashing but I know the new code isn’t running because it is publishing events I changed. It has flashed a few times but it is very difficult to troubleshoot when I don’t know what code is running on it.
Any ideas on how to fix this?
) intended - but counterintuitive, to say the least
- behaviour of the “build and flash” button, which should better be called “build (but only if no .bin present) and flash” button.
” button first and then the (
