Can someone help out with the upgrading firmware on particle electron that are in the product version with new code running because after the upgrade a new code built on the newer version is required . Is there a possible way ?
I guess you have no physical access to the Electron.
What system version have you currently got on your device?
Can your app code not run on that version?
