Firmware exit after loop with red led
If I run the local flash the firmware works correctly.
If I send the firmware with API functions (https: /api.particle.io/v1/devices/) the setup and loop functions is performed then the red LED lights up and restarts by running the setup again
Help me
Knowing your code would help.
Also the the number of red flashes after the SOS pattern (… — …) helps to distinguish between different crash reasons.
My first blind guess would be that your Particle.function() handler does not return an int when it should.
Ok thank you
Solved
