File on /build reverted to much earlier version
Help!
Code that I wrote/saved last night disappeared. The file I worked on at http://spark.io/build reverted to a much earlier version…
I definitely saved the file, in fact the code (with latest changes that are no longer visible on /build via my browser) it is now running on my Spark Core firmware where I flashed it.
  1. How can I retrieve that code?
  2. What went wrong, and can I prevent this from recurring in future?
  3. Can I work on my files locally and SFTP them to the Spark.io/build server? (That is a solution to #2)
Sean
You can use Spark-cli to compile code and flash it to the core using the command:
spark flash core_name folder_name
@jgoggins or @dave might be able to help look into this…
