Hi All,
I have a machine that sending all parameters (vibration , temperature, speed, etc) to HMI via Ethernet cable (RJ45) and I want to use particle electron with Ethernet Overlay Shield for Particle Photon/Electron (https://store.ncd.io/product/ethernet-communications-module-lantronix-xport/) to send these data via cloud and monitor it using ubidots dashboard for example, is that possible? i am thinking to use RJ45 T-Adapter, 2 Port, Shielded so one for the existing HMI and one to my shield,
if this is possible please advice with the steps that i need to follow ?
Thank you very much and i am looking forward to hear from you.
Maj
Gen 3 devices work great with Ethernet -
