dcbw
January 1, 2026, 5:12pm
1
A while back I accidentally flashed my alpha unit to a later-than-supported version (140), and while reflashes back to 130 work, it fails to boot with 1095865 Error code 9e002001 at boot_whitelist_prot.c Line 292. I suspect partitions may be messed up.
Is there a factory image available I can flash to my unit? I do have manufacturing data backed up.
dcbw
January 6, 2026, 5:19pm
3
@ericpietrowicz I did try those and it grabbed Tachyon_NAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory.zip but I wasn’t sure if that file was valid for Alpha units or not. It failed to flash with the following logs; given the partition erase error I figured the factory image was not correct for the Alpha units. But maybe it’s something else?
Command: /var/folders/vx/f37kxr416qng8bhwv2tfmcy00000gp/T/qdl202601-37762-10suejt.blmu/qdl --storage ufs --serial XXXXXX --zip Tachyon_NAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory.zip --include SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/prog_firehose_Qcm6490_ddr.elf SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/rawprogram_unsparse0.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/rawprogram1.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/rawprogram2.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/rawprogram3.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/rawprogram4.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/rawprogram5.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/rawprogram6.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/patch0.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/patch1.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/patch2.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/patch3.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/patch4.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/patch5.xml SG560DNAPAR60A03_BP01.003V01_Ubuntu20.04.003.51.305V02_factory/patch6.xml --skip-reset
sahara_run failed. Continuing to firehose
waiting for programmer...
successfully erased 6+0x80
successfully erased 134+0x80
successfully erased 262+0x80
successfully erased 390+0x2
successfully erased 392+0x100
successfully erased 648+0x200000
successfully erased 2097800+0x200000
successfully erased 4194952+0x10000
successfully erased 4260488+0x800
successfully erased 4278920+0x10000
successfully erased 4344456+0x0
successfully erased 965+0x0
successfully erased 6+0x1a
successfully erased 32+0x20
successfully erased 64+0x100
successfully erased 320+0x0
successfully erased 518+0x80
successfully erased 646+0x0
successfully erased 3136+0x180
successfully erased 3520+0x180
[ERROR] failed to erase 19408+0x1000
[ERROR] firehose_run failed
Unable to complete device flashing. See logs for further details.
