Hi Particle,
I'm using the B-Series in the UK. After activating it, I noticed 6% signal strenght. Do you have any advice for what to add as an extended antenna or to improve signal strenght?
Thanks!!
Hi Particle,
Thanks!!
Hey there! The cellular environment is dynamic and definitely contingent on things like location, physical enclosure, ambient noise etc.... It's worth establishing that that 6% number is directly related to your physical location by moving around with the device and seeing how the metric changes.
Also -- the most important metric to look at is signal quality, though signal strength is of course a useful thing to keep in mind as well.
Here are our docs on antennas: Antennas | Hardware | Particle
