How can I export data from the particle console to be able to use it on another platform or to create a database.
The console is merely a visual interface for displaying data, it doesn’t store any data on its own. You can use a subscription on the Server Sent Events to listen to your data stream and do with that as you please.
In addition to that, you could use webhooks to direct that data to a different destination directly.
A search on the forums for Losant or Ubidots should give you an idea.
Losant has a free version that has worked for all my needs for the last 1+ years. Ubidots is not as free as it used to be so you have to start paying with them sooner FYI.
