Thanks @zachary, please forgive my ignorance but would this be added to either the apache or nginx config file depending on the setup?
No problem at all! Others will undoubtedly have the same question.
If youāre serving static file content, then yes, youāll add that to the webserver (apache, nginx, etc.) config.
If youāre responding to the request dynamically (with php, node, ruby, python, C#, java, etc.) then you could either set the header in the webserver config (as above) or in your application code. Just look in your web code frameworkās documentation for how to set a header on the response, which often (kind of a āgotchaā) must be done before you start serving the actual HTML content of the page.
Great thanks @zachary! Iāll have a go at that tomorrow and post my results then
(And yes I am just serving static content for the time being).
@G65434_2 I think the problem stems from using an AJAX request for OAuth implicit flow. Because the response does a redirect, you really should be using a normal HTML form. Otherwise the AJAX request is the one being redirected, not the page, which causes the CORS error you are seeing.
Thanks @bryce
How would I go about writing a form for this? (Sorry thereās a few different ideas going around here and Iām not a web expert!). Would it be something along the lines of this??
<form action="https://api.particle.io/v1/orgs/myCompany/customers/email=email&password=password&response_type=token&client_id=myappID" method="post">
email: <input type="text" name="useremail"><br>
password: <input type="text" name="userpassword"><br>
<input type="submit" value="Submit">
</form>
Use email and password for the names, and hidden inputs for the other arguments, like below:
<form action="https://api.particle.io/v1/orgs/myCompany/customers" method="post">
<input type="hidden" name="response_type" value="token" />
<input type="hidden" name="client_id" value="myappID" />
email: <input type="text" name="email" /><br>
password: <input type="password" name="password" /><br>
</form>
That worked! Thanks @bryce, I spent a crazy amount of time trying to get that to work with ajax.
I have noticed that my client-id now shows up in plain text when viewing the page souce, is this ok? Although I suppose it was trivial to find it before from the developers tool by looking at the JS source anywayā¦
client id being exposed is fine, client secret is the one you want to protect. Implicit flow exists to not expose the secret without the need for a server.
can you please summarize what is your current progress with " Example Web Setup App " ?
What actually works, do you have any code to share ?
As I lately received info from Particle guys, that they are not going to make āorganizations friendlyā JS SDK for at least 3-4 months, Iām wondering what really can be done with JS using HTTP API.
Iām planning the same as you - create customer + setup WiFi + claim
thanks !
Hi @kefir135
Sure thing, Iām currently away from my main computer but Iāll post some code as soon as Iām able.
So what Iāve currently been able to do is this:
-Create a login using the JS library
-Create a āregister new userā button below the login one for creating new user accounts
-Subscribe to data pushed from the Particle devices in a dashboard type setup
-Send WiFi credentials to the device using the SoftAP library
What Iām yet to do is add a couple of lines of code in my SoftAP JS to āclaimā the device when itās WiFi is setup. This shouldnāt take too long however.
My company is currently going through quite an expensive freedom to operate and IP viability investigation so I canāt quite release my website yet but I will as soon as I can. In the mean time I will post some code fragments to help others along. (Once I get back to my computer).
Cheers,
Hi @G65434_2
thanks, I do have the whole web ready (ready for the device Iām building, with functions and variables) , including SoftAP wifi setting. It allows login with particle credentials.
What Iām still missing is:
eating OAuth credtials (for the app)
creating particle users with it
claiming device
BR
Anyone following here, Iāve started a bit of a tutorial over here: Tutorial for a simple web app
I have been following this conversation and other posts on this topic and I still have some issues in successfully claiming a Photon (Simple Authentication). Following the example of @G65434_2 and the tutorial, I have succeeded in:
- Creating a OAuth client ID.
- Create a customer + getting customer access token.
- Create a claim code using: https://api.particle.io/v1/device_claims?access_token=access_token_of_customer_created_in_step_2.
- Send WiFi credentials using SoftAp (using the work from @mebrunet - https://github.com/mebrunet/softap-setup-page ), including the
claim_codeparameter generated in step 3 in the url ( http://mydomain.com/softap/?claim_code=claim_code_generated_in_step_3 ).
According to JavaScript console, the claim code is successfully sent to the Photon. From what I understood reading the docs, when the Photon gets the WiFi credentials and connects to the Internet, it sents back the claim code to the Particle Cloud to finish the claiming process, but on my Particle Dashboard I cannot see any claimed device and not even a customer created.
I have read the docs, but I cannot figure out what I am doing wrong.
@kefir135, @bryce, @jeiden any ideas of what might be happening?
