Recently the owner/credentials of our account have changed, is there a new token we need to use? Is this visible/available from our account?
Where are you getting the error from?
- Cloud REST API. You should be using API users that don't expire, or you can create a token using
particle token createin the Particle CLI that does not expire. - Particle CLI. Use
particle login. The CLI tokens expire every 3 months. - Particle Workbench: Use command palette Particle: Login. Tokens are shared with the Particle CLI.
Error is coming from Postman
You'll need to generate a new token using particle token create and set it following these instructions.
Thank you Rick, this was very helpful. Communication is back online.
