Error setting up wifi
I get the following error when I run:
particle serial wifi
? Which device did you mean? /dev/ttyACM1 - Photon
? Should I scan for nearby Wi-Fi networks? Yes
? Select the Wi-Fi network with which you wish to connect your device: 37G
Attempting to configure Wi-Fi on /dev/ttyACM1
! Something went wrong: [Error: Error: Permission denied, cannot open /dev/ttyACM1]
I was finally able to get it to work.
I thinking pressing setup, releasing then pressing mode worked. Maybe the lights are too close for my eyes to distinguish color.
The “correct” way to solve this issue is to use a udev rules file so that you will have permission to access the device.
Edit: You must also be in listening mode (blinking blue) as well.
