Hi guys. I’m trying to connect my Raspberry Pi to Particle.io and unfortunately I am unable to claim my Pi…
Just installed particle through bash <( curl -sL https://particle.io/install-pi ) on Raspbian. Logged in and entered a unique name.
Any suggestions on what I should try to resolve this?
dreamER
September 23, 2020, 1:54pm
2
HI,
The Particle on Raspberry Pi project has been discontinued
Hi hasanals,
We no longer officially support the Raspberry Pi as a part of the Particle ecosystem. Although I do know some work was done in the past on it that is still sometimes being used by the community.
@gusgonnet ’s example is a great reference point and I’d certainly start there.
That’s unfortunate! I was really hoping to tell Google to turn my lights on
Are there any workarounds for my Raspberry Pi, or does particle.io support arduino nano IoT?
dreamER
September 30, 2020, 2:25am
4
I guess that the only reasonable solution will be to join Particle Devices Family
Step 1
Step 2
Step 3
But… if you really need to run the stuff on RP I’m positive that with some workaround with this doc:
as this is a step by step how to start
you gonna be able to do your needs as i’m still running
buz DK gateway on my pi and is working greate
