I have the following error when I start the setup without being logged. This error was found using two different devices (galaxy tab api 17, samsung young api 16).
I’m using:
compile 'com.android.support:appcompat-v7:23.1.1’
compile 'com.android.support:design:23.1.1’
compile 'io.particle:cloudsdk:0.3.1’
compile ‘io.particle:devicesetup:0.3.3’
and the error:
FATAL EXCEPTION: main
java.lang.RuntimeException: Unable to start activity ComponentInfo{com.example.hakken.hakken/io.particle.android.sdk.accountsetup.LoginActivity}: java.lang.NullPointerException
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2114)
at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2139)
at android.app.ActivityThread.access$700(ActivityThread.java:143)
at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1241)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loop(Looper.java:137)
at android.app.ActivityThread.main(ActivityThread.java:4963)
at java.lang.reflect.Method.invokeNative(Native Method)
at java.lang.reflect.Method.invoke(Method.java:511)
at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:1038)
at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:805)
at dalvik.system.NativeStart.main(Native Method)
Caused by: java.lang.NullPointerException
at io.particle.android.sdk.utils.ui.ParticleUi.enableBrandLogoInverseVisibilityAgainstSoftKeyboard(ParticleUi.java:23)
at io.particle.android.sdk.accountsetup.LoginActivity.onCreate(LoginActivity.java:56)
at android.app.Activity.performCreate(Activity.java:5184)
at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1094)
at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2078)
Apparently the error is in:
ParticleUi.enableBrandLogoInverseVisibilityAgainstSoftKeyboard(this);
Note: I am using OAuth credentials
I really appreciate any help you can provide.
