I have a Google Apps Script function that I would like to run a published Particle Cloud function. But I am getting a 400 error. Here is my Apps Script Function:
function sheetOpened() {
let access_token = "<ACCESS_TOKEN>"
let device_id = "<DEVICE_ID>"
let url = "https://api.particle.io/v1/devices/" + device_id + "/sheet_opened";
let options = {
method: "POST",
headers: {
"Authentication": "Bearer " + access_token
let response = UrlFetchApp.fetch(url, options);
The really weird thing is that this curl request works completely fine:
curl -X POST -H "Authorization: Bearer <ACCESS_TOKEN>" \
https://api.particle.io/v1/devices/<DEVICE_ID>/sheet_opened
And I believe there is not difference between the requests. Does anyone know what is wrong?
I ran UrlFetchApp.getRequest(url, options) and this is the request that was generated:
"url": "https://api.particle.io/v1/devices/<DEVICE_ID>/sheet_opened",
"payload": "",
"method": "post",
"followRedirects": "true",
"contentType": "application/x-www-form-urlencoded",
"headers": {
"X-Forwarded-For": "<REDACTED>",
"Authentication": "Bearer <ACCESS_TOKEN>"
"useIntranet": false,
"validateHttpsCertificates": true
Hi, it could be that the POST is missing the body:
not 100% sure though...
I have added a payload to the request:
let options = {
method: "POST",
headers: {
payload: {
arg: "test"
But that didn't seem to do anything. I got the same error
I would try adding the acces_token in the body too:
This worked! Thanks. My complete code is this:
let access_token = "<ACCESS_TOKEN>";
let device_id = "<DEVICE-ID>";
// Url to cloud function (named `sheet_opened`)
// Request options
let options = {
// AJAX Verb, it can work with "GET", but it is probably better to use "POST"
method: "POST",
payload: {
// The `arg` field is not mandatory, but if you want to add it you can
// arg: "argument"
access_token: access_token
// Send request, and get response
// Log response
Logger.log(response);
Awesome, good work. I always get confused as to where to place the token, if in a header or the body.
Best
