I am unable to connect through an web path post like this:
<form action="https://api.particle.io/v1/devices/[device name]/led?-d access_token=[access code]" method="POST">
However, using the same access code with curl works? Any ideas?
Kurt
Kurt
Hi @kjwilde
I edited your post to make the HTTP command readable. Click the little pencil to see the markup syntax I added.
The -d syntax is unique to Curl and not used elsewhere. You could use & to append the parameters to the URL but I would really recommend you take a look at this tutorial I wrote that uses a different and more flexible style:
Maybe I"m missing something here. I’ve tried both forms:
<form action="https://api.particle.io/v1/devices/[device name]/led?-d access_token=<access code>" method="POST"
and
<form action="https://api.particle.io/v1/devices/<device name>/led?<access code>" method="POST">
They both result in:
"error": "invalid_request",
"error_description": "The access token was not found"
Ah-ha! It simply needs removing the -d and leaving the access_code= bit in. I must have misunderstood. Thanks.
