Hi There
I wonder if changing the antenna provided with the Electron’kit for a different one could alter the Electron certification conditions.
I need to use an aluminum enclosure and I do not think the internal antenna provided will operate if it does.
Thanks for some help.
@Meson777, my understand is that the antenna must be of equal or lesser gain than the one supplied by Particle.
OK, if that condition is met that do not affect the certification, am I right?
Correct
OK, thanks for your answer.
