Hello. I received my Electron today and am attempting to get it connected. I am in a building that does not permit cellular signals, so I’m attempting to join Wifi.
Prereqs:
I’m in listening mode
I do have the battery connected
Even though it’s not being used I do have the antenna connected (for fear to burning up the radio without a load connected)
The “particle setup wifi” command does report the wifi network properly, however, when I say either yes or no to “Should I try to auto-detect the wireless security type” I get no response. EDIT == I get this response, but nothing past this; Detected WPA(PSK/AES,TKIP/TKIP) WPA2(PSK,FT-PSK/AES,TKIP/TKIP) security
I’ve allowed this to sit for quite a while and tried multiple times.
Any ideas?
If you have access to WiFi, I’d recommend the Photon over the Electron.
