I am unable to flash new firmware to my Electron. The IDE will at times indicate that the flash was successful, however, the electron does not flash magenta and I know for a fact that it is running an older program. I checked that the IDE version is compatible with the device (0.4.8). I also tried to upload the blink program and even though it stated that the flash was successful the electron was still running the older program. I also attempted to reset the electron but it did not seem to work. Below is a copy of my code:
//The following program receives data values from sensors and transmits values to the cloud
float turbidityValue = 0.0;
float orpValue = 0.0;
String orpValueString = "";
float phValue = 0.0;
String phValueString = "";
float ecValue = 0.0;
String ecValueString = "";
//for turbidity sensor
pinMode(A0, INPUT);
//for ORP, pH, and EC sensors
pinMode(D2, OUTPUT);
pinMode(D3, OUTPUT);
Serial1.begin(9600);
//orpValueString.reserve(30);
//phValueString.reserve(30);
//ecValueString.reserve(30);
turbidityValue = getTurbidityValue();
orpValue = getORPValue();
phValue = getpHValue();
ecValue = getECValue();
Particle.publish("turbidity",String(turbidityValue));
Particle.publish("ORP", String(orpValue));
//Particle.publish("pH", String(phValue));
//Particle.publish("EC", String(ecValue));
Particle.publish("version", "2.0");
delay(1000);
float getORPValue(){
float value = 0.0;
//y value
digitalWrite(D2, LOW);
//x value
digitalWrite(D3, LOW);
Serial1.print("r\r");
delay(100);
orpValueString = Serial1.readStringUntil('\r');
value = atof(orpValueString);
return value;
float getpHValue(){
float value = 0.0;
//y value
digitalWrite(D2, HIGH);
//x value
Serial1.flush();
delay(100);
phValueString = Serial1.readStringUntil('\r');
value = atof(phValueString);
return value;
float getECValue(){
float value = 0.0;
//y value
//x value
digitalWrite(D3, HIGH);
Serial1.flush();
delay(100);
ecValueString = Serial1.readStringUntil('\r');
value = atof(ecValueString);
return value;
float getTurbidityValue(){
int sensorTurbidityValue = 0;
float voltage = 0.0;
sensorTurbidityValue = analogRead(A0);
voltage = sensorTurbidityValue * (5.0 / 1024.0);
return voltage;
