I am using Electron to send sensor data to our servers. It is supposed to wake up every 5 minutes, retrieve sensor data, establish communication with network, send the data and go back to sleep. The system is powered through AC so I am not at all concerned about power optimization (I am providing 5V power to VIN pin in addition to the Li-Po battery). I am using the following code:
#include <HttpClient.h>
#include <JsonParserGeneratorRK.h>
#include "Particle.h"
#include "Serial5/Serial5.h"
SYSTEM_MODE(SEMI_AUTOMATIC);
SYSTEM_THREAD(ENABLED);
#define TOKEN "xxxxxxxx"
#define SERVER "xxxxxxxx"
#define PORT 8080
#define APN "xxxx"
STARTUP(cellular_credentials_set(APN, "", "", NULL));
String ACCESS_TOKEN = TOKEN;
void avertListeningMode(void);
Thread thread("avertListen", avertListeningMode);
void avertListeningMode(void) {
while(true) {
if (Cellular.listening() == true) {
Serial.println("Listening Mode found. Averting it by rebooting.");
Cellular.off();
delay(300);
System.reset();
delay(300);
HttpClient http;
http_header_t headers[] = {
{ "Content-Type", "application/json" },
// { "Accept" , "application/json" },
{ "Accept" , "*/*"},
http_request_t request;
http_response_t response;
FuelGauge fuel;
void setup() // Put setup code here to run once
request.hostname = SERVER;
request.port = PORT;
void loop() // Put code here to loop forever
delay(5000);
Serial1.begin(9600);
pinMode(WKP, INPUT_PULLDOWN);
delay(2000);
Serial.println("WKP is HIGH. Waking up.");
if(!Particle.connected()){
Serial.println("Unconnected! Connecting.");
Particle.connect();
if (waitFor(Particle.connected, 150000)
Serial.println("Connected.");
//Retriving sensor data
//Communication with cellular network
else{
Particle.disconnect();
Cellular.disconnect();
delay(2000);
Cellular.off();
delay(2000);
if (digitalRead(WKP)==HIGH){
do{
Serial.println("WKP is still HIGH.");
digitalWrite(B0, HIGH);
delay(100);
digitalWrite(B0, LOW);
delay(1000);
}while(digitalRead(WKP)==HIGH);
Serial.println("WKP is LOW. Going to sleep.");
delay(100);
Serial.end();
Serial1.end();
delay(1000);
System.sleep(WKP, RISING, SLEEP_NETWORK_STANDBY, 300);
The system worked as expected for few days. Afterwards, I observed that Electron is waking up as usual, after every 5 minutes, but it is not attempting to connect to the network (LED breathing white from waking up till going to sleep). I got this from the serial output:
So it seems like for some reason Particle.connect() is irresponsive. What could be the reason behind this? Do I need to put a Cellular.on() before Particle.connect()? AFAIK, it is not needed.
