Hello,
My Electron is connected to an ultrasonic sensor, and runs a simple program to output the distance measured to serial port. It also publishes an event every few seconds, which gets to Particle Cloud, and eventually to a channel on ThingSpeak. So far, so good!
However, if I put the device into Soft Power mode I find that thereafter it can never re-establish cellular connectivity… When ‘woken’ it goes into Looking For Internet mode for a long period, then slowly pulses white (couple of seconds), then slowly pulses blue (couple of seconds). After that it goes back into Looking For Internet mode.
I have found one way to get it to re-establish connectivity, and that is to re-flash the firmware.bin file that I downloaded when going through the device setup/registration process. Once this completes, the device eventually gets into Connected mode.
I can then flash my code again (from VS Code) and the program is running and end-to-end the system is working.
For me this scenario is 100% reproducible, and so I don’t think it is related to power, signal strength, or use of third-party SIM.
I don’t have anything explicit in the code for connectivity, so I assume the mode is AUTOMATIC.
I will continue to trawl the forum, but if anyone can help, it would be appreciated!
Regards
Chris
Other things I’ve tried
- re-connecting the battery
- re-flashing just the code (not firmware)
It’s running firmware 1.0.1
