In the datasheet of Electron (3G modem), it says “Power Class Class 3 (24 dBm) for all bands”. Is there any way to manage the transmitting power (lower the transmitting power when it is not necessary to transmit the full power)?
Please allow me rephrase my question as following
How much control do we have on setting the 3G modem? such as idle mode, active mode, connected mode? or the Electron firmware has taken care of this and minimize the power consumption of the 3G modem to the best possible way?
You can use any AT command the ublox datasheet describes via Cellular.command()
